Throttle Body Bypass
Old Mar 6, 2002 | 01:50 AM
91 L-9ate's Avatar
91 L-9ate
Default Throttle Body Bypass
What all consists of a throttle body bypass
thanks
:confused:
Old Mar 6, 2002 | 02:02 AM
Ruby_Roadster's Avatar
Ruby_Roadster
Default Re: Throttle Body Bypass (91 L-9ate)
Removing the hose connections into/outoff the TB that are used to heat the TB for colder climates. Basically, you remove the the hose connections from the TB and re-join them together via a joiner kit available from Corvette Central, MAD, Ecklers. The idea is to reduce the heat in the air intake pasing through the TB - colder air burns better.
VetteNoob's Avatar
VetteNoob
2' of 5/8" Heater hose and 2 hose clamps, some plugs if you want to cover up the unsightly stems coming off your TB after you remove the heater hoses from the TB or a coupler to join 5/8" heater hoses. Im not good at describing what exactly to do so Im sure someone else can explain that better. you can get the hose and clamps from an auto parts store for around $5.
[Modified by VetteNoob, 12:03 AM 3/6/2002]
Old Mar 6, 2002 | 02:28 PM
92BAV's Avatar
92BAV
https://www.corvetteforum.com/techti...D=61&TopicID=2 :)
To Throttle Body Bypass
