L98 exhaust manifold porting with pics
These have got to be the worlds worst exhaust manifolds that were assembled by a blind man with a stick welder. I'm not interested in dropping big $$ on long tubes, so I thought I would try "helping" the stock manifolds. This was all just removing the AIR tubes and cleaning up the welds. I gotta think this will help some. The socket is used for size comparison.
Before:
After:
Before:
After:
Lookin' good!
Watch how "thin" you grind the welds back on the tubes don't grind all the welds out of there since you want it to stay together when it expands/ contracts. If your still running an EGR riser you need to grind the crap out of that tube inside the "8" tube. I've seen those sticking down about 3/4" into the manifold. to think that's how these where when the left the factory. Look at the collector side of the manifold there is usally a bunch of slag and excessive weld beads on those puppies.
Lookin' good!
