Removing Oil Pan on 1993 Corvette
Hey all,
Once again, did a search but didn't find anything. I am trying to remove the oil pan to replace the timing cover gasket and since I had to drop the oil pan I figured I would put a new gasket on that as well. Do I really have to remove the Left Catalytic Converter and starter motor and flywheel cover plate (whatever that is) ?
Furthermore, are there other names for the flywheel cover plate? Even though its in the FSM like that in the oil pan section, the section referring to the flywheel never says anything like that in the flywheel/transmission section.
Thanks!
Thanks!
On cars with an auto trans, the cover is nothing more than a plastic shield held on by four (IIRC four) small screws. It just covers the flex-plate and torque converter. No sure but i suspect there's something similar on a manual trans car. Some guys just leave it off once removed.
I never tried removing just the oil pan on a LT1, but I suspect the job would be easier if the starter and cat were out of the way. Dropping both is pretty easy.
Jake
Jake
on other small blocks, I've just loosened up the bolts enough to get the pan to drop down to facilitate R&R of the front timing cover. when it went back on, some RTV go layed in the corners of the original gasket and oil pan rail when the timing cover got popped back into place.
I can't say for sure on a C4, but a lot of times, the engine needs to come out to completly remove an oil pan on a chevy small block.
On my 96 I didn't have to remove either cat; the exhaust system stays in place.
Undue the engine mounting stud nut (one per side)
Place large piece of wood under oil pan; place floor jack under the wood and jack up engine one to two inches
place small pieces of wood approximately one inch thick between bottom of engine mount and frame
release and remove jack
Disconnect negative battery cable
drain oil
Remove the oil filter
Remove the oil filter mount
Drop, remove the starter
Remove stamped flat piece of sheet metal from bottom forward end of bell housing,
undo oil pan screws 7/16ths " heads (1/2 " nuts on forward most and aftermost studs)
remove oil pan rail reinforcing strips
remove oil pan.
installation is the reverse
drain oil
remove oil pan.
drain oil
remove oil pan.
drain oil
remove oil pan.
Jake
Well the last person to do it used so much RTV on the oil pan that its still on with all of the screws out. God this is turning into such a nightmare. I got the timing cover off and now I can't get it back on.
oh yeah...you'll have to pry it off some with an angled prybar type of tool. A little coaxing is gonna be needed, the small block front cover has flustered plenty of people over the years. there is a certain intangible skill experienced mechanics have regarding the use of force...enough to get the job done without breaking things..fine line, usually. you might need a helper to pull the front lip down while you get the cover in place.
X2, worked the same for me.
Thanks, Mike
Thanks, Mike
drain oil
remove oil pan.
drain oil
remove oil pan.
drain oil
remove oil pan.
drain oil
remove oil pan.
Time to revive this thread. The above method works for me just fine. Thanks for posting it. In the middle of a cam swap now. I'd like to add something to the list of steps. Here it is.
Before pulling pan down, remove low oil level warning sensor in the side of the pan. Mine was hanging up on the pump pickup and I accidentally broke it when dropping the pan.
I removed the pan on my 93 saturday night. Didn't have to jack the engine up. Didn't drop the starter just unbolted it and moved it against the exhaust. Also removed the oil level sender first as per the fsm.
