O.K. I got my stroker crank in today and noticed my GM pilot bearing slides into the end very easily. Well my question, is it supposed to be loose fitting? I thought about dimpeling around the hole and using a little locktite?
Any input would help,
No it isn't supposed to be loose, not as tight as an old rotor grease seal but you don't want it spinning inside of the crank either. Have you tried one of the bronze ones?
I heard the Bronze one's are better for street use.
When I was young I put one in that wasn't as tight as it should have been. The car drove funny, it shifted like s--t. I figured it was spinning with the input shaft. A week later I got a new one and installed it and things were vastly improved. Now adays I hate doing anything twice! And now I could never get that old cast iron Hemi trans in my old car by myself now!
