Official LT1/4l60E to LS2/4L60E Swap (Instruction + Pix)
I am putting my stall converter in so it will give me alittle bump.
What do you think of this setup? Worth the money? Will it clear?
http://www.kwikperf.com/lsx_ac.html
Will your same compressor work with this?
Sits in the org LT holes. The engine will be moved foward about 13/16 give or take a little of the org BH location. Pic of the LS sitting on the LT x-member. The mounts shown are at stock height as the rubber mounts. I think i ended up turning them down to about 1 3/4. I had to use solid because the engine has no room to move left to right in my app. I cannot help with the spacing on the c-beam as I am using a ZF. If using the stock setup on the front, the k-member will have to be cut if using a/c. I used a Sanden compressor and is moved in about 2 inches and still had to cut the k member to be able to service it in the future. Hope this helps
Where did you get yours?
http://forums.corvetteforum.com/c4-t...read-pics.html
#34
Stereo Im not sure if it is effected. If it is Ill rip it out and do a double din touch screen radio.
AC controls Im working on now. Basically I may buy a kit to relocate it to the top of my passenger engine side. Than Ill need custom lines made. Im searching for a shop that is experianced in this. I want to keep it. I do have a write up for AC but it requires the cutting of the k member.
ABS should work along with everything else. Its all in the wiring harness.
Basically I lose minor functions that I dont mind. This is my toy not my DD so I dont mind losing out on somethings for the greater cause.
*** UPDATE TODAY*** Wire harness is sent out they will have it wednesday or so. I orded my Longtube headers but they need to send them out to get coated. I wont get those til like monday. Im still waiting to get a shipping number on my engine. I havent got one. Im starting to worry. He said it will be shipping today. I hope I dont get burned.
#36
I dont remember the height rite off the top of my head. But those would be stock replacements, I am unsure of that a phone call to pfadt and they could tell you. I made mine out of 2 1/2 inch aluminum bar stock.
Quick Time makes the BH.
#38
Well Im worried alittle now. I called the carrier he said that he will be shipping the motor from and they have no record. They said nothing coming to your location. I hasn't responded back after last night I texted him. But he posted on LS1tech at 11pm. And he logged in this morning. I just called him now no answer left a message.
Should I be worried I bought the motor on Thursday?
***Update*** Fuel system is in, I may start to fab the lines tonight.
#39
