What else should I change?
Old Apr 27, 2010 | 10:21 AM
Whitecloud's Avatar
Whitecloud
Default What else should I change?
I am changing/flushing out my radiator this week and will replace the top radiator hose and vacum out all the debris by the radiator. What else should I do whild I have everything out? I think I will take the overflow tank out and clean it out with sand and rocks. Any suggestions are appreciated. Thanks
Old Apr 27, 2010 | 01:04 PM
ch@0s's Avatar
ch@0s
Do all the hoses the bottom one will probably have to be ordered. You wont want to be stranded over one hose and then have to order it.
Old Apr 27, 2010 | 01:09 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Since you have the L98, and you'll have the radiator out to clean around and under it why not replace the rubber fuel lines in the front of the engine. They get old over time and could crack causing a leak.
Old Apr 27, 2010 | 01:53 PM
runner140*'s Avatar
runner140*
Hoses, upper and lower. Full system flush. Replace with a 50/50 mixture of distilled and anti-freeze. Replace the radiator cap.
Replace the t-stat. Pull the radiator and fully clean.
You'll be surprised at how much cooler you will run.
Old Apr 27, 2010 | 02:24 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Make sure that you drill 1/8" holes in the new thermostat prior to installation.
Old Apr 27, 2010 | 03:01 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Never heard that before. What's the reason for adding the holes?
Old Apr 27, 2010 | 03:17 PM
jon0108's Avatar
jon0108
ended up using a clothes hanger and a rag to clean the inside of my overflow
Old Apr 27, 2010 | 05:10 PM
pmihaltian's Avatar
pmihaltian
Slingshot
L98 engines have a problem with getting ALL of the trapped air out of the cooling system. When air is trapped in the system your low coolant light will come on intermittently. Worse yet, trapped air can cause hot spots in the system which can lead to engine overheating, premature wear and other damage. See the attached write-up on how to properly Burp an L98 cooling system.
Old Apr 27, 2010 | 06:16 PM
ch@0s's Avatar
ch@0s
I just put a towel on my shoulder and pat it on the back.
Old Apr 27, 2010 | 06:49 PM
jon0108's Avatar
jon0108
Very good. I did this the other day when I thought I properly burped my system. Ended up finding out I was over a half gallon short because of trapped air
Old Apr 27, 2010 | 11:23 PM
Whitecloud's Avatar
Whitecloud
Thanks for the great advice.
To What else should I change?
