Dash Light don't work
Old May 25, 2010 | 10:09 AM
busybeeme's Avatar
busybeeme
3rd Gear
Default Dash Light don't work
My 1990 Corvette runs great, NO mechanical problems. Everything about the car is in perfect shape except the DASH LIGHTS do not work. In addition, the SEAT BELT and CHANGE OIL LIGHT--- STAYS ON and I can’t reset set it. The air conditioner works great, the horn blows, the inside door lights and map lights work. Have checked all fuses.
I put in a new ECM, which did not fix it. Now I am told that it is probably the BCM. However, in some of the online forms I have read, it seems that if there is a problem with the BCM that the car will not run right. Any help or suggestions you have would be appreciated.
thanks,
Johnnie
Old May 25, 2010 | 12:09 PM
jfb's Avatar
jfb
Dash lights may very well be burned out, they don't last forever.
MyFirst90coupe's Avatar
MyFirst90coupe
Stupid question but have you checked the bulbs?
My seat belt light stayed on too, I took the bulb out of that one.
Old Aug 19, 2010 | 05:00 PM
Mixednuts's Avatar
Mixednuts
Another Stupid Question: How do you get to the SEAT BELT bulb to take it out. Mine stays on as well.
Old Sep 20, 2010 | 08:45 AM
red 90's Avatar
red 90
I hope by now you have your dash light problem resolved, was it a fuse?
Old Sep 22, 2010 | 10:31 AM
Mixednuts's Avatar
Mixednuts
All resolved on my end thanks to this forum.
To Dash Light don't work
