1986 vehicle speed sensor confusion
86 with manual and 3.07 rear gear.
I am looking all around and can't find the sensor. Talked to a recycler and he said the PMG part of the sensor (silver body) is the same for an auto and a manual. it is just the end gears and the shaft gears that are different.
can anyone confirm this?
VSS type relates to diff ratio ; not trans type
Different rear end ratios require different speedo gears and the VSS varies according to the driven speedo gear used.The two VSS used each only take a certain range of gear sizes
See
http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
See
