86 won't idle
Old Jun 10, 2010 | 05:03 PM
slt780's Avatar
slt780
Navigator
Default 86 won't idle
Hi,
I have a 1986 that just won't idle. It starts easily enough but I have to continually feather the gas pedal to keep it running. It seems that when I step on the pedal the car wants to stall but when I release it, it seems like it revs up (the reverse of what I would expect to happen). It runs rough by the way, with the occasional "pop" (like a backfire). As soon as I release the pedal, it stalls. Any ideas?...this thing is driving me nuts. (No pun intended)
Thanks,
Danny
Old Jun 10, 2010 | 05:39 PM
turbodiesel's Avatar
turbodiesel
i have weird idle to like it wants to stay at 500 rpms and sum times stahls out.
i wanna see what sum say ,
sounds like sensor or injectors , or old fuel filteR?
Old Jun 10, 2010 | 05:44 PM
slt780's Avatar
slt780
Navigator
Would an old/dirty fuel filter cause symptoms like the ones I've described?
Old Jun 10, 2010 | 05:57 PM
turbodiesel
very possible
go to the dealer get a new one there like 12 bucks and start there.
Old Jun 10, 2010 | 07:46 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yes a new filter is worth the time. It sounds like it's starving for fuel, either pump failing or plugged filter.
Old Jun 11, 2010 | 12:55 PM
djoksch's Avatar
djoksch
I had to replace the idle bypass solenoid in my 87' located on the bottom right side of the throtle body. It allows air to pass when the butterflies close when you release the gas pedal. Your computer should throw a code if this is the problem. I am told that this is a common easy to fix problem.
Old Jun 11, 2010 | 01:13 PM
engle1147's Avatar
engle1147
Check the car for stored trouble codes first.
Doing some standard maintenance is always a good thing.
Fuel pressure checks might be in order.
Clean/check the IAC (idle air control sensor).
Check voltage at the TPS (throttle position sensor) should be be ~ .54 volts.
Might want to check the exaust system to see if it is flowing freely and not glowing at the converter(s).
To 86 won't idle
