Engine vacume and braking
Old Jun 19, 2010 | 03:28 PM
slickfx3's Avatar
slickfx3
Default Engine vacume and braking
900 rpm 10.5 lbs
1400 rpm 14 lbs
2600 rpm 17 lbs
the braking now seems a little hard
is this enough vacume?
how can I increase it?
timing?
Old Jun 19, 2010 | 03:40 PM
MK 82's Avatar
MK 82
Should be. Check that it is holding vacuum. And it is inches of mercury-not lbs.
Old Jun 19, 2010 | 04:53 PM
94z07fx3's Avatar
94z07fx3
I'm puzzled by the numbers. If they are inches of Hg then why is vacuum seemingly building with RPM. I would expect an inverse relationship between RPM and vacuum.
Old Jun 19, 2010 | 05:32 PM
slickfx3's Avatar
slickfx3
maybe i don't know what the heck i am reading, but it does hold steady....
Old Jun 19, 2010 | 05:34 PM
94z07fx3's Avatar
94z07fx3
I found this site a while back and thought it was a good read with a neat interactive bit at the bottom of the page too.
http://www.secondchancegarage.com/public/186.cfm
Old Jun 19, 2010 | 05:51 PM
ex-x-fire's Avatar
ex-x-fire
Is that a ported source of vacuum you are reading? The vacuum should be strongest at idle, try hooking it to the manifold near where the boosters connects & see what it reads. You can try advancing the ign. timing, & you can also advance the cam timing too, both may increase manifold vacuum alittle.
Old Jun 19, 2010 | 06:38 PM
slickfx3's Avatar
slickfx3
super ram
teed it off the rear ports, you saying i need more vacume?
Old Jun 19, 2010 | 07:01 PM
ex-x-fire's Avatar
ex-x-fire
Your psi reading are of no use in vacuum, b/c vacuum is measured in inches of mercury,HG, anyways you should have 16.5HG. or up at idle(you won't have much assist w/ the throttle open, so those rpm readings don't matter), but most will be near 20HG, stock cams. The more you open the throttle the vacuum gauge should move torwards zero.
With the psi readings you gave us, I can't tell you if you need more vacuum, take a picture of the gauge while the car is at idle.
To Engine vacume and braking
