speedo gear for a dana 36 with 3.54 gears?
I am looking for a speedo gear for my vette I installed 3.54 gears and need to change the speedo gear to give me correct speeds. Which speedo gear do I need with 3.54 rear gears?
What rearend ratio did you have before swap?
You may have to swap both drive and driven speedo gears dependent apon what you originally had
See
http://forums.corvetteforum.com/c4-t...eedo-help.html
See
Here's a link to a supplier of speedo gear parts and a chart to figure out which one you need.
http://www.transmissioncenter.net/sp...n_______va.htm
their web site is www.transmissioncenter.com . You will find what you need there.
Steve
Steve
