I replaced the Delco opti cap and rotor with an MSD vented and replaced Driver side header gasket and replaced driver side SP wires.
Now car idles good(slight miss and miss was there before, did not do plugs), rev in park and car revs right up. Put it into drive and car has no power and the valves clatter like mad.
Check the wires and they are on right, is there anyway to put the opti on wrong?
I must have put the SP wires on wrong, but would the wires on wrong explain the valve clatter.
Are you sure that what you're hearing is valves? There wouldn't seem to be a connection to an ignition problem. Could you be hearing a misfire due to plug wires or ??
Double checked the wires and they are on correct and snug.
Has anybody else ever put a MSD cap and rotor on a Delco opti and did you have any problems?
Narrowed it down to either bad cap and/or rotor or I somehow put the opti on wrong.
I don't know of any way that ignition components can cause the valvetrain to make noise. The noise you are hearing likely is either not valves or is unrelated to the ignition.
Talked to MSD tech support, they were not much help. Guy said it could not be the cap if the engine revved in park, but I am thinking I have verified everything but the cap. Going to take everything back off and recheck the opti is on right and cap is clean.
Any reason I cannot start the car w/WP off and balancer on?
If the timimg is far enough off, you get cylinders firing when the valves are open or slightly open and that will cause valve noise, from the explosion pushing the valve closed.
Think I found my problem(I hope), when my starter went out, it took my my knock sensor out. In replacing everything that went wrong, I somehow did not replace it, so I am hoping that it is the problem, I will know tomorrow.
First off there should never be an explosion. Thats detonation(spark knock). That could be what you're hearing.
If compressive gasses are managing to close your valves...you better be prepared to replace some lifters, push rods, valves, and/or the cam because it would have to push all of that with it. Most likely the valve, which is the case when cam timing is off or the valves float and they get whacked by a piston. And it takes a pretty decent whack to bend a valve, and they usually stay open when bent.
There is NO WAY ignition timing could force a valve closed. Not gonna happen. The situation you described would cause backfiring through the intake or the exhaust.
I see that in your next post you mention the knock sensor. Yes. That could cause noises. But it would be spark knock. Not valve train noise.
Ok, knock sensor is not the issue, forgot it ran fine when it was broken. So I am back to I either screwed something up or I have a bad cap and/or rotor.
Really do not want to go back into the opti, but it looks like I am.
you wouldnt be the first person on here to post about bad MSD parts (specifically opti)
Can't blame MSD, it was my fault. I jammed the opti on wrong, but in my defense, it took little effort to put it on. The gear in the Delco opti is cheap aluminum, but it was my fault, I was tired and hot and did not take my time.
Happy to hear you got it sorted out Randy. We all make mistakes, but it is rare when someone is honest enough to admit it. Sad because there is much to be learned from our mistakes, ask me how I know.
Well it is not all sorted out yet, still have to replace the bad knock sensor and I need to replace my cats, but at least I can drive the car now.
No reason not to tell the truth, only person I would hurt would be me by not telling the truth.
Stop by Harbor Freight Tools and get an 02 sensor wrench (crow's foot design). It'll make the job easier. And don't forget a dab of anti-seize compound for the new sensor (and possibly PB Blaster) for the old one to make removal a snap.
And I thought I was the only one who pays for his mistakes. I try not to make the same one twice, but I can always find a new one.
