MPG sensor in '85
Old Aug 20, 2010 | 11:05 PM
Guinea Jay's Avatar
Guinea Jay
Default MPG sensor in '85
Not a problem as much as an observation. I reset my fuel rate sensor a few months ago. It was reading 18.9 mpg at the time. I've left it on and been watching it very very slowly climb back up from 0.0.
This is my daily driver so I've put plenty of miles on it and it finally hit 15.0 mpg today. Does everyone's do that? Seems ridiculous.
Old Aug 21, 2010 | 10:47 AM
ex-x-fire's Avatar
ex-x-fire
I guess it depends on how you drive it. After you reset it, it'll read like the instant mpg reading for awhile, then slow down, usually in under 50 miles.
Has your driving habits changed? What's the coolant temp reading? If its running under 185*, it'll really effects mpg.
Old Aug 21, 2010 | 11:17 AM
3D-Aircrew's Avatar
3D-Aircrew
Hotter being better?
Old Aug 21, 2010 | 04:45 PM
ex-x-fire's Avatar
ex-x-fire
Hotter is better for mpg, you don't want to cook your engine. A good 195* is the best for mpg/performance. I'm doing alittle experiment over at SV, I installed a 205* stat & got over 3.5-4 mpg more then my average over the years, which was around 24mpg. I'm trying a couple other things to get to 30mpg, I don't know if i'll make it though, the 84 is the least fuel effiecent of the c4s. I wouldn't recomend running a 205 stat where its hot, I'm in Wi. so its not super hot like it is in the south.
Old Aug 21, 2010 | 10:21 PM
Guinea Jay's Avatar
Guinea Jay
Nah, temp has been steady 170s to 210 in this car for years. I just think my sensor is funny to start at 0 and work it's way up literally 1/10 of a mile at a time for months. Guess I should just be happy all my 25 year old dash lights still work, regardless of what they say I can always flip the switch and ignore it.
Old Aug 22, 2010 | 02:31 AM
Pwnage1337's Avatar
Pwnage1337
there isn't a MPG sensor, the ECM determines that reading based on the amount of air/fuel is being used, air fuel ratio, speed and some other things
Old Aug 22, 2010 | 12:29 PM
rons85's Avatar
rons85
And, in the '85, at least, there is a value in the constants table (in the ECM BIN file) called "Display Fuel Flow Rate". If you like to amaze your friends, you can edit that scalar value and make the MPG readouts show about anything you want.
Look, we're getting 300 MPG!
Harder to make it actually be Accurate. The scalar value says it's in GPH, the value that works for mine, that causes the displayed MPG values to match the Real MPG, is about 4.31. That's with 24# injectors in there, and "stock" fuel pressures.
Old Aug 22, 2010 | 01:24 PM
383vett's Avatar
383vett
When you reset your mpg indicator, if the car is at an idle, it'll start at 0. As you drive, it'll calculate your mpg from the reset moment on. If you were idling for a while after the reset, the computer will have some catching up to do to calculate your overall mpg. Try resetting the indicator when you are on a cruise. It'll start out at over 20 mpg and work it's way down when you hit stop and go traffic. You might feel better about your mileage.
To MPG sensor in '85
