do i have dana 44?
Cruising
do i have dana 44?
do i have the dana 36 or the dana 44? my car is a 92 with the six speed. how much power can each of these rear ends handle? im doing an LS motor swap 408 stroker and will be producing ALOT of power.
Most likely you have a D44 because it is a manual. Check your rpo codes.
G44 - 3.07 Rear Axle Ratio - D36, optional; D44, standard, pre-1992.
G92 - Performance Axle Ratio - Shows performance axle selected.
GHO - 3.54 axle ratio - D44 only.
GM1 - 2.59 Rear Axle Ratio - D36 only.
GM3 - 3.45 Rear Axle Ratio - D44 only.
GU2 - 2.73 Rear Axle Ratio - D36 only.
