C4 exhaust question
Old Sep 1, 2010 | 07:45 PM
eatmydst1234's Avatar
eatmydst1234
Default C4 exhaust question
I was putting the exhaust back under my '86 for the first time in several months. one of the mufflers is rusted on the backside, but i just want it on temporarily untill I can afford to replace them. Well while I have the exhaust off I gutted the main cat, as the county I'm in, in Ga has no emissions, yet. Anyways, back to the story just before the cat there was a hanger of sorts, had 2 bolts that bolts bottom half of hanger to top. Well, when putting the bottom half up against the pipe to bolt it onto the top half of hanger, neither of the bolt holes line up. I can move it a little and get one bolt in, but the other will never line up. It's kind of like the top half got bent while exhaust was off car, I had dual exhaust on it with no cats and found the car to be too loud so wanted to revert back. Now to the question, does that hanger have to be there? The exhaust seems to be very stable, it's doesn't move much at all.
Old Sep 2, 2010 | 07:04 AM
MyFirst90coupe's Avatar
MyFirst90coupe
I'm not 100% certain but, did you try the bottom half both ways? I think I had to flip mine when I went to put my exhaust on last weekend.
Old Sep 2, 2010 | 11:32 AM
eatmydst1234
i tried both ways. i guess i'll be a guinea pig. lol
Old Sep 2, 2010 | 11:53 AM
MyFirst90coupe
The thing that I would be concerned with is the stress that section is under from the engine/tranny moving around. I think without that hanger you might end up with leaks from around the cat.
Old Sep 2, 2010 | 12:10 PM
Deepa's Avatar
Deepa
i think a 3 1/2" exhaust clamp will fit those holes. Use the bottom half of the 3.5" clamp and use the top hanger.
Old Sep 2, 2010 | 02:41 PM
j-wireman's Avatar
j-wireman
The answer to your question is YES. You certainly do need to use the bracket in front of the cat. It keeps the front Y-pipe and cat from moving side-to-side or up-and-down and banging against the floor tunnel. Without it, the only thing between the exhaust maniflold and the mufflers holding up the exhaust would be that thick rubber-band hanger. That hanger only prevents downward movement and not upward or side-to-side movement and is very "stretchy".
Frankly, I would replace BOTH exhaust hangers, especially the rubber band hanger. The hanger stretches and the holes tend to get elongated over time. The end result will be about 1/2 to 3/4 of an inch more road clearance.
Hope this helps.
Old Sep 2, 2010 | 09:53 PM
eatmydst1234
Hope this helps.
Thanks for the info, I drove the car to a friends shop to put it on a lift to have more room to work with and I bent the top part of the hanger back down so it would bolt back up. I somehow bent it when I had the duals on that didn't utilize that hanger.
Old Sep 3, 2010 | 12:25 PM
eatmydst1234
one more question, what is the easiest way to attach the air pipe to the manifold? I was out driving the car and had a horrible noise emit from under the hood. got back home because I was only like 2 mins from home and don't see anything messed up. After closer inspection I saw that the air pipe is vibrating on the manifold when the engine is under load.
To C4 exhaust question
