'91 Automatic stumbling on 1-2 shift
Old Oct 22, 2010 | 11:59 AM
Chuck Lewis's Avatar
Chuck Lewis
Default '91 Automatic stumbling on 1-2 shift
New user, first post and first time Vette owner (4 weeks now).
My '91 with auto-trans is having trouble on the first to second shift. If you have your foot in it it does fine but when normal (slow) driving it stumbles bad. It's like the ignition is totally shut off for a second, the car totally falls on it's face then accelerates normally. I do have a code 32 for the EGR which I haven't done anything about yet. Would this cause the stumble?
Thanks, Chuck
Old Oct 22, 2010 | 12:45 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
here's some info on the EGR. I would address this first and then move on IMO
http://www.misterfixit.com/egrvalve.htm
Old Oct 22, 2010 | 01:21 PM
C4happy's Avatar
C4happy
Old Jan 9, 2011 | 08:06 PM
Chuck Lewis
Default update...
I finally changed the EGR valve along with the injectors this weekend and the engine definitely runs smoother and no more check engine lights, but the first to second shift still stumbles under normal driving. Idling out shift doesn't stumble, foot to the floor shift doesn't stumble and manually shifting it at various rpms doesn't stumble, just normal driving. I did notice that the 'first to fourth' light comes on right before first to second shift when it stumbles. The 'first to fourth' light just applies to standards, doesn't it. Why woukd it be coming on with my automatic?
Thanks, Chuck
Old Jan 11, 2011 | 12:43 PM
Chuck Lewis
I've been searching and searching, still can't find any answers or even common issues to my problem. Any ideas?
Thanks, Chuck
Old Jan 11, 2011 | 01:13 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Never heard of a 1 to 4 light in an auto.
Old Jan 11, 2011 | 01:55 PM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
On my 89, you can see where the light would be in the DIC (cheaper to use common parts?).
Maybe his doesn't have the original ECM or ECM Chip? Not sure if that would have anything to do with the stumble, but may have something to do with the shift light coming on????
Old Jan 18, 2011 | 11:00 AM
Chuck Lewis
My 17 year old son is driving the car now. He says that the 'one to four' light does not always come on before the stumbling shift.
Thanks, Chuck
To '91 Automatic stumbling on 1-2 shift
