406 Finally gave up, new build coming
Old 11-19-2010, 10:20 AM
bjankuski
CF Senior Member
Default 406 Finally gave up, new build coming
Last weekend, I was as I was accelerating up an off ramp in second gear I decided to jump on the gas for fun and as soon as I hit it the crank snapped in two towards the front of the engine. The engine kept running but it vibrated badly and was leaking oil from the balancer seal. I have not taken it apart yet but the balancer wobbles up and down at least 1/2 an inch. I limped it home 10 miles and by the time I was home the oil pressure had dropped 20 LBS and the oil temperature had climbed 20 degrees. My gut feeling is the crank snapped between the #1 and #2 main bearings but the broken pieces are staying engaged enough to keep the car running. I will have to take it out and survey the damage.
No matter what the outcome is I see a new 434 on the way!!
bjankuski is offline
Old 11-19-2010, 10:58 AM
USAsOnlyWay
CF Senior Member
USAsOnlyWay's Avatar
Bummer but it sounds like you've got it taken care of
Already have an idea on build specs?
USAsOnlyWay is offline
Old 11-19-2010, 02:01 PM
JackDidley
CF Senior Member
JackDidley's Avatar
Bummer. My car is running really good, I'm afaraid its about to break something also.
JackDidley is offline
Old 11-19-2010, 02:21 PM
Pwnage1337
Pwnage1337's Avatar
10's for sure. At least it happened right before off season and not during summer
Pwnage1337 is offline
Old 11-19-2010, 02:25 PM
syco_cop
CF Senior Member
...and drove it home for 10 miles? That's amazing it kept going.
syco_cop is offline
Old 11-19-2010, 02:26 PM
pologreen1
CF Senior Member
pologreen1's Avatar
GEEEEZ. Good thing you made it home. It sounded great not that long ago.
I guess some things are just meant to be.
Good luck with the new one.
pologreen1 is offline
Old 11-19-2010, 04:14 PM
bjankuski
CF Senior Member
It sounded good right up to the big bang sound! I have a feeling the spun balancer and detonation issue related to the spun balancer contributed to the crank failure. I suppose the 1000 or so 1/4 mile runs and 200 plus dyno runs didn't do it any favors either.
For seven years I beat the tar out of this engine and it finally gave up. Oh well I am not disappointed because now it gives me an opportunity to play with a new combination.
Old 11-19-2010, 05:59 PM
tpi 421 vette
CF Senior Member
tpi 421 vette's Avatar
Sounds like you got your monies worth out of the 406! 1000 runs is alot! Well this gives you an excuse to move on to a bigger and potentially better engine. Good luck with the new build.
tpi 421 vette is offline
Old 11-19-2010, 10:18 PM
JAKE
CF Senior Member
JAKE's Avatar
I'm sorry to read about your engine failure but I like seeing that you've kept a positive mental attitude over the whole thing.
We could all learn from this though.
You know what would be of GREAT BENEFIT? The autopsy results.
If you would post all the parts, specs and what you find once you take apart the engine it would greatly help those in their next engine build.
I see many posts about valve train failures, spun brearings, etc. but too seldom do I see a listing of the parts involved, the clearances, the probable cause, etc. It would help in future discussions about cast Vs forged cranks, different brands of both rotating and recirprocating parts, balancers, etc.
All that may well help prevent others, including me, from experiencing the same thing.
Just my suggestion.
Jake
JAKE is offline
Old 11-19-2010, 11:23 PM
GREGGPENN
CF Senior Member
GREGGPENN's Avatar
Gee, I noticed where Brian already posted the probable cause. He had a thread explaining what happed with his balancer (and what brand it was). It's in a recent thread of his. (I know you do well with the search function, Jake. )
Brian,,,that's too bad. Hopefully, you're as motivated to do a new motor as you sound. I'm also surprised you made it the 10m back home. Sounds like you used good stuff -- besides that balancer.
GREGGPENN is offline
Old 11-30-2010, 02:39 AM
pologreen1
CF Senior Member
pologreen1's Avatar
Well Brain started the build yet?
Old 11-30-2010, 08:30 AM
dclafleur
CF Senior Member
dclafleur's Avatar
Sorry to hear the old motor gave up but eager to hear what the new build is!
dclafleur is offline
Old 11-30-2010, 09:33 AM
bjankuski
CF Senior Member
I have not even pulled the engine out yet. I have been concentrating on my 555 rebuild in my real drag car.
I will get to the 406 in December.
Brian
Old 11-30-2010, 09:59 AM
Aardwolf
CF Senior Member
Aardwolf's Avatar
Let me know if you want any help wrenching on it. I got mine back running.
Aardwolf is offline
Quick Reply: 406 Finally gave up, new build coming
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
