Can you mix pistons?
What are the pros and cons? I have a LT4 that needs 2 pistons replaced. Can"t find OEM so am looking at having to install after market. What are issues with mixing old a new pistons in car,or should I replace all eight?
If you are going to go the poor man's route, you'd be better off getting a couple of good used pistons from an engine rebuilder's tear downs if you can find one dimensionally in spec still. I've been known to make a repair like that on occasion, but never on a V8. Usually 8 stock hypereutectic pistons aren't that expensive.
I -just- took a set of the stock flat-tops to the machine shop on Friday with a block that is getting worked over - if you can wait until after thanksgiving I'll see if they've still got them and I can ship them to you - just pay the shipping.....
Received 3,043 Likes
St. Jude Donor '05
Check with Summit racing they have some budget priced pistons that Im sure will fit your app, seen them for 100/set +
I think you should build a blowup engine and have some fun while you build the engine that you are going to keep in the car. Take it out and drive the blowup engine to it's limits just after you finish building your permanent engine, and when it blows, put your overhauled engine back in.
