Average Price to build stroker L98?
[Modified by Glock'94, 8:06 PM 4/6/2002]
I remember the stroker kit being an additional $300.oo over the normal kit.
+ the hand grinding/prepping the block.
Good to here you're building up your motor!
L83
L98
LT1
LT4
LS1
LS6
(You'll notice two missing.)
[Modified by KYVette90, 9:03 PM 4/6/2002]
Are you positive about that statement? :eek: :confused:
Seriously, the block I used added about $225 to the total cost of the buildup.
This place also http://www.dirttrackthunder.com
Here's a post from an earlier thread:
Well, here is what I have spent this year on my '88 to give you an idea.
383 short block-Scat cast crank, Eagle I beam rods, Speed Pro hypers, new oil pan, double roller timing set,dampener, and flywheel, all balanced, -$1,930
Heads-new in box, but used, Air Flow Research 190's-$1,200
Comp Magnum roller rockers, custom roller cam and lifters,pushrods-$700
Full Lingenfelter Super Ram, ported, used-$1,000
Lingenfelter billet throttle body, used -$300
Hooker Super Comp headers, coated, 2 1/2" dual exhaust-$1,000
Dana 44 with 3.07's used-$440
Spicer U-joints-$120
Raptor 2,600 stall converter, new in box, but used -$150
Belts, hoses, fluids, seals,plugs, cap and rotor, thermostat-$150
Nitto Drag radials and 17" Epsilon wheels,used -$250
Simpson Voyager Helmet-used $125
So, doing all the work myself and shopping wisely, I should have a pretty stout car for a little over $7,300. Unfortunately, this is what it costs to go fast with a durable,reliable, matched combination. A lot of people don't want to admit what they have spent on their cars but that is what I have spent, so far.........
[Modified by Fastguy, 3:52 PM 4/7/2002]
