What's the best way to change the 700r4 trans fluid at home?
Thats . Granted I can no longer do what I used to. I was in this bussiness for over 30years. But I do not think I changed my oil 2 times in my life why? because by the time I buy the oil filter deal with the mess ect it is not worth my time for the couple of dollars I saved unless I already have it on the lift and doing something else. In life no matter what it is you have to have trust in what people do for you. I don.t care if they love my car or if it gives them an orgasm. Do what I want and do it right and I am happy. Just like you trust your doctor,carpentor ect. I still love to work on my car. But if I cannot or choise not to work on it like anything else I need to have trust in others.
tblt44 first want to say sorry did not mean to be offinceive For some reason I have felt that way about oil changes for many years. Yep they do get messed up at times but for the most part usaly not a problem. And damn hard to beat the price. For over 27 years I was incharge of a fleet of over 300 vehicles and 7 techs. (until I had to retire) Maybe durning this time it took some of the pleasure out of working on cars. Somethings just seem to "me" to be more wise or cost effective. I do respect all you and all the other guys who want to do as much as you can. I wish I could do more now then I can but more then anything else I wish I had the passion to do more.
Peace of Mind knowing that you have worked on your vehicle correctly, is well worth the time and money spent!
Well, I bought a 4 post lift during the summer so I didn't have to crawl under the car anymore. Even tho I have 8' ceilings I can get the car high enough so I can sit on a mechanics roll around seat and work on the Vette. To recoup that investment I will definitely be doing my own work as much as possible.
As others have suggested, I will be doing the pump out option with the suction pump, drop pan, change filter, add fresh oil, disc top line, start car and pump fluid in converter out repeating until the fluid is clean and new. I'll save the pumped out fluid to use in my chainsaw chain oiler since it's been thru a filter.
I know what you are saying about peace of mind. But I try to have trust that when I paysome they do it right. You just cannot live life doing everything your self because you have no trust.
Cars were my profession. They are still my hobby but for the most part after all these years doing most anything on a car is more of a job then pleasure.
willie the trust argument can go on forever and ever. I am happy that you like, and are capible of doing the work on your cars. It can be fun, challanging, and rewarding. I also know people mess up it happens. And sure no one cares about anything you own as much as you do. Still to "me" if I can get a oil change for about what I pay in materals and not have the mess ect I am going to do it all day.
Dave
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Here we go again. If your fluid is burnt, you would want to drop and clean the pan, change the filter and button the thing up with a new gasket. Fill the pan with 4 quarts of flesh fluid. Somewhere between the radiator and the tranny, disconnect the upper (return) line going to the tranny and put a hose over it. Put the hose in an empty gallon container. Run the motor for a minute or so until the container is 3/4 full. This will be old fluid out of the converter, cooler and lines. Stop the motor, put another 4 quarts in the tranny. Run it again. Stop the motor. Do it once more until you have used a total of 11 or 12 quarts of fluid and the fluid running out of the hose is clean. Check the fluid level and drive away.
Here, from the C4 horse's mouth himself.
Most of us know him and few of us met him
