94 Lt1 PCM values. Help!!
Old Jan 3, 2011 | 11:46 AM
spanishvette86's Avatar
spanishvette86
Default 94 Lt1 PCM values. Help!!
Hi all, and Happy New Year.
A friend has a problem with his 94 and we need the PCM values. I mean, how many volts or Amps has to be each pin at PCM to find a problem who lives into the car since 4 months ago.
Do anyone have any diagram or table with those values?
Thanks to all from Spain
Old Jan 3, 2011 | 12:02 PM
pcolt94's Avatar
pcolt94
That information for with voltage at pins is not exactly published with the diagrams in the FSM.
However if you stated exactly what the problem with the car was, I'm sure some specific information could be given. What is the area of the problem?
Old Jan 3, 2011 | 01:15 PM
spanishvette86
Thanks for your help
The car doesn´t want to start. I knew about this car today, because his owner called me totally desperated, so I don´t know a lot about it, but i will tell you the few things I know:
- The last time the car worked, it had a Code 42, but it runs. The owner goes to 5500 rpm a moment, and a few minutes later, the car starts to lose power until it dies.
-When he try to crank, the car has false explosions at Intake Manifold and mufflers.
- The Opti is changed. It´s new, an MSD. The problem continues, exactly the same.
-Distribution is OK
-Gas injection is OK
-Spark appears so soon (out of point)
-PCM revised by Mid America.
Thats all I know for the moment.
Any ideas?
P.D: Excuse my English, not my natural language
Old Jan 3, 2011 | 02:27 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
No codes on an LT1 and no start - can you find a working coil and ICM and swap them in to see if that is the issue?
Old Jan 3, 2011 | 03:07 PM
pcolt94's Avatar
pcolt94
I would at this point check for fuel pressure. Get a gauge on it and see if your loosing pressure. Maybe the fuel pump is bad (or filter). Get to get the simple stuff out of the way first.
Old Jan 4, 2011 | 11:21 AM
spanishvette86
It has code 42. The coil is new and...ICM? Thats the PCM? Sorry, mine´s is a L98, im a little lost at LT1
Thanks for your reply
I would at this point check for fuel pressure. Get a gauge on it and see if your loosing pressure. Maybe the fuel pump is bad (or filter). Got to get the simple stuff out of the way first.
Ok, i´ll tell him.
Thank You!
Old Jan 4, 2011 | 04:05 PM
STL94LT1's Avatar
STL94LT1
Ignition Coil Module, it is attatched to the coil.
To 94 Lt1 PCM values. Help!!
