Engine assembly and have 1 brace I can't ID the location for...
Old 01-24-2011, 09:01 AM
bwiencek
bwiencek's Avatar
Default Engine assembly and have 1 brace I can't ID the location for...
1989 C4, 6-speed, newer style denso a/c compressor - I have one last brace that I can't figure out where it goes - it's about 5.5" long, has the tabs with holes on a very slight angle and in the same 'rotation' - here's the braces I have installed:
- Long brace from A/C upper bolt to header
- Brace with 'L' shape from water pump to a/c bracket back side
- Brace from a/c bracket to fuel pump block-off plate
- R motor mount to p/s pump
- Intake to AIR pump bracket
- Alternator to header
I've got this one last bracket that I'm scratching my head on where it went....
EDIT - Added pic of support rod/bracket brace:
Old 01-24-2011, 10:57 AM
0Paul Ruggeri
Former Vendor
Paul Ruggeri's Avatar
What year is your car?
Old 01-24-2011, 11:01 AM
c4cruiser
c4cruiser's Avatar
Gonna need a pic and the year of car to help out.
Old 01-24-2011, 11:03 AM
engle1147
Support Corvetteforum!
engle1147's Avatar
"I always end up with extra parts after I rebuild 'em"...it does makes the car faster since now it is lighter!
Old 01-24-2011, 11:25 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Starter brace possibly
Old 01-24-2011, 11:47 AM
jeffp1167
jeffp1167's Avatar
I'll try and get pics to visually ID, but I have one last brace that I can't figure out where it goes - it's about 5" long, has the tabs with holes on a very slight angle and in the same 'rotation' - here's the braces I have installed:
if it has the denso compressor there is another brace that goes from the a/c bracket to one of the bolts on the fuel pump block of plate.
Old 01-24-2011, 12:18 PM
bwiencek
bwiencek's Avatar
The vehicle is a 1989 C4, all stock accessories, 6-speed transmission.
I don't have one on there - where did that one go from/to? I'm guessing the back of the starter to the block somewhere?
OH yeah - got that one too...
I'll try and get a pic this afternoon when I can get to the garage...
THANKS for all the ideas so far!
Old 01-24-2011, 12:23 PM
Muffin
Muffin's Avatar
Another vote for an A/C brace.
Old 01-28-2011, 03:49 PM
bwiencek
bwiencek's Avatar
Pic of support:
Any ideas?
Old 01-28-2011, 04:56 PM
jeffp1167
jeffp1167's Avatar
Old 01-28-2011, 05:39 PM
bwiencek
bwiencek's Avatar
Nope - not it - I've got that one on - plus it's got a slight bent angle to it and on the top it's got a nut welded to the brace to capture the bolt coming through the bracket.
Old 01-28-2011, 05:45 PM
UNCLEBILL
UNCLEBILL's Avatar
I have a 1990 and when I ripped everything out to clean and paint all the engine parts; I had a brace just like that left. It turned out to be the brace under the air pump by the alternator...same length and size.I accidentally put the part on the passenger side during tear down and should have stayed on the drivers side parts bin.
Hope that helps...
Bill
Old 01-28-2011, 10:52 PM
bwiencek
bwiencek's Avatar
Hope that helps...
Bill
Where on the air pump / alternator? The only one I recall is the one that goes to the engine block bolt for the motor mount and it's from the power steering bracket? I've got that one installed but If there's another one there I can't remember where the heck it goes!
Old 01-29-2011, 01:26 AM
VQT88Vette
VQT88Vette's Avatar
Looks like it's from the air pump to the intake mainfold, tie in next the the driver side front injector.
Old 01-29-2011, 02:15 AM
tpi 421 vette
tpi 421 vette's Avatar
That is exactly where it goes.
Old 01-29-2011, 04:06 AM
UNCLEBILL
UNCLEBILL's Avatar
Its been 3 years since my experience. Sorry for my wrong placement. I know it went under the air pump. Should have gone out to the garage for a proper look.My excuse is that Im retired and have "Sometimers"
Bill
Old 01-29-2011, 07:50 AM
jeffp1167
jeffp1167's Avatar
you should have 3 of those braces on the a/c bracket
To Engine assembly and have 1 brace I can't ID the location for...
Old 01-29-2011, 10:13 PM
bwiencek
bwiencek's Avatar
Bill
Thanks -I know I had one that went from the intake manifold to the air injection pump's back-side - if that's the one you're talking about I've already got that one installed (at least I thought I remembered doing it) Guess I'll double-check tomorrow night when I've got time to get out to the garage and work on it a little more and take another inventory of where I have braces installed...
I think I've gotten all 3 - off the top of my head - one from the bracket to the fuel pump blockoff, one from the bracket to the water pump bolt, and then one from the a/c pump upper back bolt to the manifold stud.
Old 01-30-2011, 12:20 AM
VQT88Vette
VQT88Vette's Avatar
Show us another picture of that bracket at a different angle
Old 01-30-2011, 09:08 AM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
If it's not one of the (3) A/C or (1) AIR support brackets, then it has to be your rear alternator brace or power steering braces. Based on it's appearance, it looks way more like your rear ALT brace.
In the OEM setup, the rear ALT brace goes from the #1 exhaust tube bolt to the outer hole on the rear of your alternator (ALT). When you go to headers, you should fab up a replacement.
Calderone has the most recent thread on this. I probably put a pic in it too.
Edit: After reading the OP, I can't think of another brace you didn't mention! Sure you don't have an extra! LOL
Quick Reply: Engine assembly and have 1 brace I can't ID the location for...
