Starting Problem?
Old Apr 11, 2002 | 12:57 AM
CG77VETTE's Avatar
CG77VETTE
Default Starting Problem?
Here is my problem. I unlock the door, get in the car, turn the key and hear a buzzing sound then everything goes dead. No interior/dash lights, horn etc. After a few minutes she starts right up. Once started, all electronics are reset as though the battery was disconnected. Next morning same thing. Any ideas?
Old Apr 11, 2002 | 01:04 AM
jfb's Avatar
jfb
Default Re: Starting Problem? (CG77VETTE)
You have the symptoms of a poor battery cable connection to your battery posts. Of course the connection is ok when it starts right up, but corrosion creeps during the night and you have a resistance connection the next morning. Get out your 5/16 wrench and remove the cables, ground first, and scrub them until they are bright along with the battery posts. Then replace them , positive first. The corrosion will be obvious when you remove the battery cables. Even better, go to an auto parts store and buy two 5/8 battery terminal bolts (brass) and through away the wimpy GM 5/16 bolts.
The buzzing you hear is the start solenoid oscillating from the poor battery connection.
Old Apr 11, 2002 | 01:09 AM
CG77VETTE's Avatar
CG77VETTE
Default Re: Starting Problem? (jfb)
Thanks jfb,
I was hoping it was something stupid like the terminals. I'll try your suggestion in the morning.
To Starting Problem?
