Updated on my Engine Build
Old 02-14-2011, 06:16 PM
nutz4c4
nutz4c4's Avatar
Yep... Sure looks like duct tape I'll tell you what to do with the pressure treated.....
Old 02-20-2011, 08:10 PM
qws
qws's Avatar
Here's an update for you guys.
Comps Utra Pro Mag 1.6 rr's
All primed up!.. had a problem with my priming tool so I took an old distributor and turned it into the new priming tool for me.
Rockers all adjusted and ready to close her up
Old 02-20-2011, 09:20 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
Love the way it looks right now...Can't wait to see it all finished up!
Originally Posted by qws
Old 02-21-2011, 10:10 AM
mseven
mseven's Avatar
looks good ED!
Old 03-06-2011, 01:22 PM
qws
qws's Avatar
Aside from just putting on two new wire loom covers and the vac lines this project is just about done.
I'm hoping that next weekend I'll start it up. Took some pics to show the new hedmen elites with the metal gasket. The gasket I'm using cost $35 but it was well worth it. Fitment of the elites on the 84 is dead on.
Drivers Side
Passengers Side
Metal Gasket
Entire Engine
Old 03-06-2011, 01:44 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Sweet build ED. It'll be nice to see another 84 shooting through the traps! Are those Elites 1 3/4"? Willie.
Old 03-06-2011, 05:01 PM
qws
qws's Avatar
Thanks.
The primaries on the elites are 1-5/8 in.
While doing this change I decided to swap out all the wire loom to new loom made by Russell performance. Mseven recommend it. Its a great product btw.
Old 03-06-2011, 05:11 PM
LD85
LD85's Avatar
Very nice!
Old 03-07-2011, 05:20 AM
Lemme
Lemme's Avatar
St. Jude Donor '10
Very nice indeed. Do those nostrils in the aftermarket hood suck cold air? Just what my 84 needs too.
Old 03-07-2011, 08:57 AM
WW7
WW7's Avatar
Ed, glad to see your close to being finished. It looks sweet,Im sure it will be a screamer. Now if Mike V gets his motor in we can have a Pete K motor line up at Carlisle this year and have 3 cars with Pete's motors in a row.. ...I hope your planning on going to Carlisle this year?...WW
Old 03-08-2011, 01:07 AM
qws
qws's Avatar
I'll be there!
And on the dyno.
I think we need some nice stickers from Pete for the cars, " PeteK Motorsports" or something.
Old 03-17-2011, 09:57 PM
qws
qws's Avatar
Default All ready to start it up
Its ready to roll. Took a few pics a couple of days ago that I wanted to share.
Ended up having tons of room around the exhaust and headers. There are no wires,fuel lines etc within 3 inches of any of it. Even the plugs and wires are a perfect fit.
You'll note in the pics below also that I located the O2 an wideband behind the reducers flanges approx 3 in. They fit up in the tunnel along side the tranny. Not the easiest to replace if I have to but they won't be to bad and I wanted them out of the way.
I also removed the resonater and replaced with new 304ss pipes, Not an X-pipe but for now this will do and I can do the Xpipe later on
Old 03-18-2011, 08:58 AM
  #33
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What did you use for the air cleaner? THat looks nice - wonder if it would work on an LT1 car (mine is MAP only).
Looks pretty!
Old 03-18-2011, 09:10 AM
  #34
Kubs
Kubs's Avatar
Received 1,716 Likes on 928 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Looks pretty!
Its a universal fit K&N with an oval opening for two blade TBs. I have one I am no longer using. PM me if you want it.
qws - that engine came out nice! Got any sound clips?
Old 03-18-2011, 09:38 AM
  #35
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
Comp Billet Cam
Duration at 0.50 230/236
Lobe Seperation 110
Valve Lift .603/.609
Great project. Well Done !
How much was the roller cam including the lifters and push rods ?
Old 03-18-2011, 02:32 PM
  #36
qws
qws's Avatar
thanks. Once I get it running tomorrow and know its ok I'm gonna do a video of it and post.
Thanks. I can't remember exactly but between the cam, lifters, rockers and push rods I'd guess around $950 or so
Old 03-18-2011, 02:55 PM
  #37
Ray Quayle
- 1986 Original Owner -
Ray Quayle's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In VII Veteran
Really nice job, Ed. I'm stalled on my "project". The machinist here in North England was apprehensive about stroker clearancing my original Pace Car block and I didn't want to let my ham fisted self loose with a grinder, so decided to put the Pace Car motor back together with original parts and new gaskets, seals, bearings and rings, seal it up and leave it on a stand in the corner of my garage. I've got on of the Summit 383 blocks on its way to me now and I'll be able to put my forged rotating assembly and AFR heads on a 4 bolt roller block. Minor set back. You've done a great job though.
To Updated on my Engine Build
Old 03-18-2011, 02:58 PM
  #38
Ray Quayle
Ray Quayle's Avatar
Cruise-In I Veteran
Pete, I've got a retro-roller cam I won't be using now that I'm going with a roller block. It's the Crane 119821, let me know if you are interested.
Old 03-19-2011, 12:16 PM
  #39
esham
esham's Avatar
Old 03-19-2011, 01:26 PM
  #40
383vett
383vett's Avatar
I heard some noise this morning. Was that the motor starting up?
Quick Reply: Updated on my Engine Build
