Crossfire to single tbi
I'd sell it for like $50. Im almost positive It's had some porting work done on it. It appears that the person who did it starts to make the runners larger but then decided he didn't want to go all the way up the runner. It's hard to explain, I can take pics if you want. I'm not sure what stock crossfire engines flow, but mine would shift at 5200 RPMs, where I think most shift at 43-47ish. But I believe I have 1.6 RRs as well. I need to pull the valve covers and check, just too lazy. My car had some work done when I got it and I've been tracing what's been done.
I am proud to announce that I am the owner of a throttle body injected vette. I got the throttle body in tonite and fired her up. She ran terrible until I realized that I had misread my own writing on the spark wires and switched 3 and 8 around. As for the IAC problem, I don't have it. Works fine like it is. I do have an SES light, but I think it's from the backwards plug wires, haven't checked the code yet. All I have left is: fix coolant leak around thermostat housing, get a bigger hood scoop to cover the big gaping hole in my hood with an air cleaner coming out or get a carb hat, swap to crossfire injectors (maybe, might just use the ones i got), and time the beast. Thanks to all and your support
I have a stock 1984 Corvette with 4 spd manual with 71K miles on it. The car is stock. all I want it to do is idle smoothly and restart when it is warm.
I tried to syncronize the TBI's using a manometer. Idle went to 1300 to 1600 rpm.
The TPS is adjusted correctly i.e. 0.46 volts at idle and 4.7 volts at full throttle.
Would replacing the fuel pressure regulators help my idle. they are the originals.
Oh and the timing is stock 6 or 8 BTC.
I need to use starter fluid to restart the warm car.
When I crank the engine fuel DRIPPLES out of the injectors. One spray of start fluid and she is running fine.
Thank you all
Thank you all
So after much debating and thinking, I've decided to swap to a single TBI unit. The swap seems straight forward. Remove old intake, add new. I'm thinking of getting an edelbrock performer TBI intake and using a 454 TBI, however I heard that the 454 doesn't have a TV cable provision so I may stick with a 350 and bore it out. Does this seem plausible? Also, can I use my current crossfire injectors in my new TB? From what I understand, changing the injectors, throws off the Computer tuning, however I'm uncertain if the injectors will fit or are capable of supporting the 350 or 454 TBI
Frankly if a custom ship would get it to start without starter fluid and idle smoothly I would buy it. Presently my interest in the car is enjoying it up to about 100 mph and drivng it through some scenic areas with a few curves and hills thrown in for fun.
If you pick up a set of 1990-1992 Camaro or firebird heads, the center bolts are angled just the way the manifold holes were. Usually, people give those away, or close to it..
they come with 64cc, and would give your engine a compression boost.
#34
Pro Mechanic
What do F-body heads have to do with anything in this thread? "vette heads have the same bolt angle, BTW, up to '91.
Your fuel pump is not charging the fuel system. Check your Fuel pump relay.
#35
Now If I am getting the surge. Then the injectors are not pulsing, I think.
What tells the injectors it is time to pulse.
Thank you this is a big help.
#36
Pro Mechanic
If you disconnect your fuel line, turn the key to "run", the fuel pump should run and fuel should flow abundantly from the fuel line, for about 2 seconds.
A better way to check is to install a "T" in the rubber fuel line between the frame rail and engine, and install a fuel pressure gauge. When the pump cycles for that 2 seconds when you turn the key on, you should see 9-13 PSI on you fuel gauge. If not find out why.
Pump not running? (likely, based on your posts)
#37
Thank you all
Thank you all
#38
Thank you all
Thank you all
#39
read this !!! http://www.thecubestudio.com/Crossfi...yBalancing.htm
I will be testing the Temperature Coolant sensor Wednesday, I hope.
One thin about the TCS. My digital readout in the car is accurate. I know this because I put a 205 degree fan switch in the car and at 205 degrees the fan turns on.
So can the TCS be bad and still give me accurate temperatures on the dash.
Should I be upgrading to a 7747 ECM even if I keep the stock CFI system?
thank you
#40
What I did not understand is I set the idle speed so that the manometere read 6 inches. Then did the front TBI unit and ultimately end up using the rear TBI unit to reduce the idle speed. Doesn't that mess everything up?
I used the WinAldl software. Interestingly enough it actually smoothed out the car, when connected. Does that mean anything?
