Tranny trouble
Old Mar 2, 2011 | 12:49 PM
dieselkary's Avatar
dieselkary
Navigator
Default Tranny trouble
Can someone please tell me. While parked on an incline my tranny slips while in reverse.
Old Mar 2, 2011 | 12:51 PM
383vett's Avatar
383vett
Manual or auto?
Old Mar 2, 2011 | 02:32 PM
aklim's Avatar
aklim
Are you SURE that the shifter cable is set up right?
Old Mar 2, 2011 | 02:35 PM
hooked073's Avatar
hooked073
Need a lot more info
Old Mar 2, 2011 | 04:23 PM
dieselkary's Avatar
dieselkary
Navigator
Default sorry
Originally Posted by 383vett
Manual or auto?
its manual 4+3
Old Mar 2, 2011 | 04:24 PM
dieselkary's Avatar
dieselkary
Navigator
yes i'm sure
Old Mar 2, 2011 | 04:25 PM
dieselkary's Avatar
dieselkary
Navigator
1987 350 factory, 4+3 MANUAL TRANNY
Old Mar 2, 2011 | 04:35 PM
hooked073's Avatar
hooked073
if you are on a steep incline it is possible you it to go backwards. The only thing holding it back is engine compression. That is if your clutch is holding correctly. That is why they have park brakes
Old Mar 2, 2011 | 08:55 PM
sailorsteve's Avatar
sailorsteve
When the slipping happens, does the engine turn? Is the car facing uphill or downhill?
Old Mar 3, 2011 | 11:45 AM
proracr's Avatar
proracr
Could be the clutch slipping, bad parking brake or low engine compression. The transmission is mechanical, so it can't "slip".
Old Mar 3, 2011 | 12:11 PM
383vett's Avatar
383vett
Let's start over. When it slips, is the motor off and are you trying to use reverse as "park" or are you trying to head uphill in reverse with the motor revving?
Old Mar 3, 2011 | 01:38 PM
dieselkary's Avatar
dieselkary
Navigator
It's facing up hill and is not running, it slips like a watch movement.. slip...slip...slip...slip
Old Mar 3, 2011 | 01:40 PM
dieselkary's Avatar
dieselkary
Navigator
No the motor does not turn
Old Mar 3, 2011 | 01:57 PM
hooked073's Avatar
hooked073
How do you know the engine is not turning? The way you are describing it sounds like the engine is turning.. sounds like you are on to steep of an incline for the engine to hold the car sould like you need to use the park brake or try 1st gear for more reduction.
Old Mar 3, 2011 | 02:50 PM
Sandpiper59's Avatar
Sandpiper59
If parked on a hill of any decent size and you use only 1rst or reverse as a parking brake, it will coast down. The "clock" sequence is simply a piston going past TDC and the next piston coming onto compression. Eventually air escapes past the rings on that one and it rotates to the next.
If you have a tired motor with a lot of leaking past the rings or valves, this will happen quickly, if it's a fresh motor with very good sealing, it will happen very slowly, but either way, it will happen.. Use your e-brake! If it's broken, fix it and in the mean time carry a small chunk of wood for a wheel chock. The appearance of your car with the 2x4 under the tire will help hasten the repair of the e-brake
Old Mar 3, 2011 | 05:14 PM
jan-erik's Avatar
jan-erik
Hi.
I have an 85 with 4+3.
I detected that when I had it in reverse and a very little elevation on the road it slipped asit was a weak clutch.
It was not it was the overdrive unit. I discovered also that the oil from the gearbox had entered the overdrive unit. When I checked the oil level of the overdrive unit it poured oil out of the check point. So the bearing in the overdrive unit slipped and had grinded a hole in the wall so I had to change the overdrive unit. This might happen with stronger than normal engines. Following Callaway (these transmissions are used in the Callaway C-4)the gearbox manage about 450ftlbs and the overdrive less. So with acceleration it should always be without overdrive unit enabled.
Ofcourse your problem may be another, but this typical symptom was slipping in reverse and then it is not!!! the clutch.
First check the oil in the overdriveunit. If not mixed with gear oil then you may save the overdrive unit and repair it.
or me it was only one option, a new and bought and 88 version which is much stronger than my stock
Hope its not this unit Good luck
To Tranny trouble
