Replacing the L98 with an LSX ... My swap
very close setup to mine. 02 ls1/ls6 manifold. fbody exhaust manifolds, tsp ms3 also. im t56 though with 4.11s. what trans and rear are you running? so far i havnt got 500 miles without killin something out back(first stock dshafts, then dennys alum shafts, and now i went 4.11s and dennys nitrous ready shafts but i killed a axle stub) good luck bud, i love the lsx
How did that Fbody exhaust line up, any pictures?
What did you do for Accessories?
ill do my best to grab some pics of the manifolds. in my 89 car they clear everything just fine and line up perfect for routing exhaust. the accessories. . .its a concoction of fbody ls stuff, and l98 stuff thats all fabbed up.
the auto should help the 36 live longer then my t56, its a bit harder on the driveline.
Took a 3hr drive but it was worth it.
Today's shopping got me ..OEM exhaust and oil pan from a 98 vette. I'm not sure if the oil pan will work but it's worth a shot.
And people think headers are a PITA!
I know there's a couple of LSx conversion threads running 'round the net. Hope they help you out.
Sucks about the HSR. I wanted to hear more feedback!
Apparently the Hot Rod Gods wanted me to have a LSX.
BTW I have the old engine apart. I don't know what caused it but I can see at least one lobe is gone looking through the lifter hole. I'm thinking my mistake was not lubing the cam after it sat. *shrug*
Swaps are a lot of work be patient......LS swap into c4 thread:http://forums.corvetteforum.com/c4-t...ml?forum_id=48
I picked up a 4L60E and 3000 stall converter yesterday.
Where did you get the speedhound parts? I thought they stopped business?
Are you going to be running the melrose swap headers too? Which oil pan are you using?
Which accessory drive?
Sorry for so many questions but I liked the work you did on the HSR conversions and the corresponding write ups. Looking forward to seeing the full write up on this one!
#35
I'm going to try and make some OEM manifolds work for now. I have a C5 batwing oil pan but I'm working on a F-body pan. I think i can make the C5 pan fit but I'm not sure. I have F-body accessories.
#37
You wouldn't think it takes 8 hrs to clean and paint an engine but it did.
I cleaned this thing with a wheel brush and tooth brush.What I couldn't reach with those I used a screw driver with a rag. I HATE CLEANING STUFF. I painted the valve covers coil brackets and fuel rail red to give it some spice. Now it's ready to drop in.
So tomorrow the short bock comes out.
Then I have to clean the engine compartment.
Disregard the ugly truck pan its just there to keep stuff out.
