Lemme's 350 87 12 sec (350hp) build - Stage 1
#322
St. Jude Donor '10
I am putting my money on the pump being past its use by date. I rechecked for leaks at the fuel tank and it is dry. The pump is in transit and is currently in Alaska ready for the big journey down under.
#323
I wouldn't worry about a fuel pump that bleeds down after 15 minutes. I've got a pump that bleeds down in 20 seconds after shutdown but it puts out plenty of fuel to not go lean at wot. Good ol LM-1. However, you are going lean at wot so you probably need a new pump.
#325
I took the bolt out and put a nut on. I screwed the bolt in as far as I could and it had only a marginal improvement in the pressure. Lucky if I got 40 psi at idle. The rapid pulsing of the fuel pressure gauge needle is still present and is a worry. The fuel pressure gauge drops to zero only 15 minutes after engine turn off.
another captain obvious question, what shape is the diaphram in inside the regulator ?
#327
St. Jude Donor '10
It came with the superram/accel intake which is secondhand but it was working OK before the pressure started dropping recently. If the new fuel pump doesn't fix the problem I will have a closer look at it.
#329
Has the gauge always pulsed or is it a recent thing? Maybe the gauge is too sensitive and doesn't have any dampening built into it. I've got a 10 year old gauge mounted on the rail and it's as steady as a rock.
#331
Probably the gauge.
