hit gas and falls flat on its azz
I have 96 LT1C4 with 43,000 and change replaced intake gaskets, oil pan gasket, replaced inner yokes, bearings,and seal in rear. Now when I hit passing gear car falls on its butt, then takes off but seems to have no power. I had a 95 C4 and it got up n went, and my 99 C5 did also, both other vette's had over 160,000 on them and were tight.
Could this be distributor, coil or other,form of electrical problem? Or fuel problem? Any help is awesome thanks..
Pasta Mike..
Pasta Mike..
Received 3,043 Likes
St. Jude Donor '05
Start with some basics, check for codes even if you dont have alight in the dash on. Check fuel pressure also.
Go from there
Go from there
You need to start with the basics.
Scroll down the main page on C4 tech from the last few days.
Troubleshooting/ driveability info from Ron, myself, & others.
Brian
