Check Engine LIghts help? Ideas?
Hello all,
So I keep having the Check engine light pop on.. It will pop on after driving a bit, sometimes go off and then come back, sometimes wont come on at all.. Very strange.. I have had it looked at twice and both times they said they found the issue and it went away for a while but keeps coming back.. does anyone have any other ideas? Im tired of taking it in and paying to have them say it is clear and just comes back again, any help would be good..
1993 40th.
1993 40th.
It sounds like an EGR code. But, hard to tell without the specific code. Find out what code it is throwing and get back to us. The code should be stored for a time even if the SES light is not on.
I have been battling a demon in mine also that has to deal with the light also. No codes stored, purely intermittent.
Have a look at my thread and see if it may pertain to you:
http://forums.corvetteforum.com/c4-t...soon-help.html
Hope it helps you out.
Don Bartlett
Don Bartlett
Hello all,
1993 40th.
1993 40th.
The SES light could be any one of a hundred things, most of them very minor. What did they say the issue was when you took it in? Codes? If so what?
Do you have any modifications? Was there any other repairs or work done recently?
How does it run? How does it drive? Any unusual noises? Mis-fires? Hard Starts, hot or cold?
