Dana 44 refurbish and strengthening for drag racing
#141
7000 aluminum is not really realistic for a case because of costs. It would be cool thou. As for the batwing being used from the d44, that could not be answered now. Hence the reason the bolt pattern of the viper being different.
#142
Are you aware of the large hard alloy presses (SMZ, KUMZ, Cleveland) that upset ingot to make flanges that are 26" thick x 40" x 40". SCC is always an issue in 7050, depending on how the final press is performed. That is why long-neck flanges are prefered over short-neck; a more gradual turn of the grains.
This can be done...
This can be done...
Regardless, I think this would be really cool project to undertake. And if we are really going to do it, we should really do it. Lets make some dies!
#143
You're right, 7050 is still susceptible to SCC but much less than 7075 (I've never seen 7050 fail a SCC test, but have seen 7075 fail). I am aware of all the large presses in the world like at VSMPO, Wyman Gordon, Albert Duvall, Alcoa Cleveland (isn't it still broken?) ect. Also, we weren't really making the grains make any sudden turns in a rectangle so I'm not too sure the point of a long neck flange versus a short neck flange. I'm guessing you're bringing it up because SCC happens through the ST grain direction and with a tighter transition, there is more of a possibility of the grain to break the surface of the flange whereas a long neck flange would have a smoother transition insuring the grain follows the general contour of the part.
This can be done, and I think we should investigate before determining it is too expensive. You might be surprised at costs from the right people.
#144
Cleveland will be back up by end of year. It was taken down in late '09 for PM when some cracks were found. VSMPO pales in comparison to SMZ or KUMZ, yet KUMZ is still focused on soft alloy. W-G is traditionally focused on other metals.
#145
That said, it seems overkill to get a forged D44 case made. AKS has made 9 second passes on his D44 rear end. He mentioned some sort of bracing to help it old up but pictures of his solution would be helpful.
#146
Try doing 60 MPH on the highway then punch it and hearing a sound that was not expected and finding the passenger side half shaft has left a scare in the passenger side rear compartment.
