Need help identifying interior wire connector/harness
I've sat in the garage with the FSM for an hour and can't find it. I don't see it in the component section or the schematics for the nearby components. Can you help?
The wires are yellow, purple, red/blk, and white/blk. Small 20ish guage.
Thanks.
On the C68, it appears to be brn, orn, dk grn, blk, between the control head and the programmer.
In the back of my Electrical Section there is a section called Harness Connector Faces, which lists the "pinouts" for most major components..
Used by the Selective Ride control FX3
Pin A Yellow wire comes from the Vehicle Speed Sensor
Pin B Black/White wire goes to ALDL connector pin B
Pin C Red/Black wire goes to the Telltale Service Ride Indicator
Pin D Purple wire comes from the Vehicle Speed Sensor
