A.I.R. Vent Pipe
Old May 10, 2011 | 11:49 AM
myk7's Avatar
myk7
Default A.I.R. Vent Pipe
Howdy, I'm putting together a basket case 89 and can't for the life of me figure out where the vent pipe for the A.I.R. system bolts to.. It has 2 bolt holes in the attached pipe bracket, looks about the same spacing as the passenger water pump bolts, but I'm now convinced it doesn't go there. Thanks
Old May 10, 2011 | 01:25 PM
tehcarguy's Avatar
tehcarguy
It's mounted using the two bolts on the right side of the a/c bracket.
Old May 10, 2011 | 03:36 PM
myk7's Avatar
myk7
Is that the right side of the AC bracket when facing the front of the engine? If so, that's the water pump bolt studs... I got it to go on there, but it doesn't seem to like it much, possibly in a bind somewhere. Thanks
Old May 10, 2011 | 04:53 PM
tehcarguy's Avatar
tehcarguy
That's how I took mine off my 86. I wish I could upload a pic for you, but my ISP thinks that should take an hour and a half.
Old May 10, 2011 | 05:10 PM
myk7's Avatar
myk7
I think it will work there, it's just that everything else was pretty obvious where things went, this didn't seem to want to go there. Thanks for your time.
To A.I.R. Vent Pipe
