Oil Leak rear of engine -oil pressure sensor ?
1988 Auto Coupe
I have had a leak at the rear of the engine for a few years, this year it is a lot worse. There is oil coming down the LH side of the block and appears to be coming from the sensor to the LH side of the distributor.
Is that the oil pressure sensor?
I have searched the forum and there seems to be some confusion on 1,2 or 3 wires etc. I found this picture
Is this the 1988 oil pressure sensor?
If so, I'm not surprised it is leaking after so many years of vibrations, there must be some metal fatigue involved - is it likely to just snap off anytime?
What exactly leaks? could it be tightened up?
I'd be grateful if anyone can give me an online address to buy a replacement. I'm in Australia and will need to order the part online.
From '89 at least ,a single unit that combined both functions was used ( 3 wires ) .Not sure when the change was made , my '87 has both
usually the units blow apart ; size of leak being dependent on by how much.
Short of taking the dizzy out impossible to determine what is actually leaking
Send me a email ,
might have something of interest to you in my spare parts dept
Hi Rod, I can see an electrical connector pointing straight up and it has 2 orange wires.
I'm going to see if I can stick a small vid cam down there in the next day or so. I have one the size of a key chain remote.
Do you have any clues for locating a replacement?
Received 1,401 Likes
If that is leaking and not the intake manifold itself, it may have somehow backed itself out of the manifold, or one of the two pieces did.
You'd have to yank it to really tell what it is, and seeing back there is almost impossible without taking the distributor out too.
They are cheap - change them both. The two wire fuel pump switch almost cost me my new 385. Emptied the oil out in less than a minute. I posted a thread on it about 2 months ago.
Cheap insurance - Change them (got them at autozone).
I wish there was an autozone near me!! I have international shipping on top of the unit costs.
If I could just go down to the shop I would buy the parts this instant,
First I have to identify the right part(s), then order them, wait for them to arrive- usually 12-14 days.
IDENTIFY the Parts - It's hard to get a picture but the bit I can see has wires, Red & Orange, coming from it and looks to go straight down to the block -
I tried to use the keychain vid cam but once I pushed it down there it's too close - this is the best picture I got from the video, in case it helps identify which part I need
I need to know which oil pressure sensor it is, then I can find the part number and start searching to see who has one and will ship to Australia
This has been very helpful. My vette has the exact same leak and I thought it was the gasket pushed out on the back of the intake manifold....nope just the oil pressure switch! I have a 90 with one wire coming out of the top which one would that be?
Cool. Cant believe it took 6 months.
I was going to mention that while you had this combination oil pressure switch -oil pressure sending unit apart you can replace the bell shaped electric oil pressure sending unit with a mechanical sending unit kit + the gauge from Summit , which reads real oil pressure instead of an electrical signal. You get real-time real oil pressure at all rpm's plus one less item to leak later on ..
its hard to imagine a worse place for GM to have installed this item on the motor, one of those things where you have to wonder what the designers were thinking ... to get to it either pull the distributor or cut an access panel from inside the car ... hardly a good set of options
there are tons of things where you have to wonder what the designers were thinking... sometimes this car seems a puzzle,a rebus,a strange way to put things work toghether without thinking who has to fix it later,you have to remove fog light lenses...remove the bumper!you have to change injectors,remove the whole intake system...it's a car for retired guys...lots of time to mess with
i tell ya I miss the days when had a '67, - open the hood and its all right there in front of you - simple, air+fuel+spark equalled go. hardly needed any special tools. then came EGR and EFI and the rest is history and lots of head-scratching ... i cant imagie what it takes to work on the 2011-2012 models...
