1986 Fuel Problem??
Old 06-21-2011, 02:12 PM
rrt898
rrt898's Avatar
Default 1986 Fuel Problem??
I have a 1986 coupe with a stock L-98. The car has 75k miles. The car starts and drives fine. When doing short trips the car is a little hard to start. I can smell gas. Some people are telling me its my injectors. That they are leaking. If this is true, I would replace all of them. What is the best brand of injectors at what lb's. Is there anything else I should replace?
thanks for the help......
Old 06-21-2011, 03:23 PM
AGENT 86
AGENT 86's Avatar
Before you replace injectors (22lbs), test the system. You will need a fuel pressure gauge.
From my 86 FSM >> http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old 06-21-2011, 05:56 PM
1986coupe
1986coupe's Avatar
I agree with Agent86. Just to clarify though, is the fuel smell coming from under the hood? If so check the fuel pressure.
From experience I had a fuel smell at the rear of my 1986 coupe. People told me it was the injectors. It was actually the seal was bad on my gas cap...cheap fix.
Old 06-21-2011, 08:04 PM
rrt898
rrt898's Avatar
The fuel smell concerns me but; the hard starting after short trips does too...What are common part failures??
thanks.....
I will test the fuel system.
Old 06-21-2011, 11:26 PM
floridamale
floridamale's Avatar
Take the vac hose off the FPR see if there is gas in the line also
Old 06-22-2011, 05:50 AM
Cliff Harris
Cliff Harris's Avatar
Could be a leaky injector.
You really need to get a fuel pressure gauge on it to see what's happening.
Old 06-22-2011, 08:29 AM
rrt898
rrt898's Avatar
I appreciate the help. I really don't know what I am looking for. If I put a fuel pressure tester on....What is the correct pressure? Also am I trying to see if the car holds that pressure or goes down? What would be the correct procedure?
Also when I pull the vac hose off the FPR and find gas...What does that mean?? Or if its dry???
thanks again....matt
Old 06-22-2011, 08:45 AM
AGENT 86
AGENT 86's Avatar
Did you read the PDF file ?
Fuel in the reg vacuum line means the diaphragm is ruptured and needs to be replaced.
Old 06-22-2011, 09:01 AM
rrt898
rrt898's Avatar
I was reading it as you replied.......Thanks again for the help
Old 06-22-2011, 03:21 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
rrt898;
Follow Agents suggestions.
He's been around the block many times and has not steered anyone wrong.
Old 06-22-2011, 09:56 PM
rrt898
rrt898's Avatar
Ok I tested the fuel pressure. With the key on 41 lbs. With the car running 36 lbs. When I turned the car off I was expecting the pressure to drop fast but; it didn't held at 40. I guess I am going back to the PDF file.
Any ideas.....
Old 06-22-2011, 10:27 PM
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
Yep.
Behind the rear of the driver's seat, the area out under the car, there is a short piece of rubber vacuum hose where they spliced the vacuum line, as the vacuum metal line came in 2 pieces on the assembly line. What is worse, is if your car got undercoating, you will have to dig around a little bit to find it. But follow the line in the undercoating, and dig at the raised area. you will find it.
Replace this hose. It is about 3 inches long and is 5/32 I think. should cost you about 50 cents at the auto parts store.
Mine was leaking about 8 years ago, and i only smelled gas after I shut the car off, or got in it to go somewhere.
Gas vapors fall to the floor, so sitting in the car made my nose low enough to detect it.
I hope that's it.
Old 06-29-2011, 10:34 PM
rrt898
rrt898's Avatar
Thanks everyone. I changed my gas cap and found that small piece of rubber vac line. (mine was almost gone). After checking everything will the fuel pressure. I finally found that the TPS was faulty. The car never ran better.
thanks again.....
To 1986 Fuel Problem??
Quick Reply: 1986 Fuel Problem??
