Newb F.A.S.T questions
I'm gonna spring for the FAST XFI 2.0, I'll install it in the fall when the cold weather season kicks in,,, I plan on more cubes for summer 2012, w/somewhat more radical setup,, so I guess its time to better understand DFI programming
For you FAST users, what functions will I loose, is there a piggy back cable to use the stock ECM or does that go away, or do I use both, what options do you suggest?
I think the basic system, injector harness, not sure about the drive shaft sensor, but I want the FAST to control as much as possible in terms of engine control
I'm gonna buy the system from a CF-Vette guy I've talked with and he will help too, but I wanted to get some input form general users as well.
