smokin in OD,4+3 tranny,85.
when cruisin down the road in 4th with the OD on, there was so much blue smoke coming out the back that I lookied like a PITTS stuntplane on the 4th of july. when I clicked the OD off, the smoke cleared up? Put it up on jack stands and found fluid on the passenger side undercarrage.Ran the car on stands and could not find a leak? What"s up with this? running aroud at slower speeds, the OD seems to be ok. When this first happened,I was doing about 75. HELP.
Was the leaking fluid pink or tan?
And check the fluid level in the OD unit. It may have stopped leaking because it all leaked
out. In fact, check all the oil levels, tranny and engine.
If you use the search function and enter "4+3" you should find threads on changing the fluid and replacing the filter. It's not too difficult and doesn't cost more than $20 to $25 to do yourself. If you can't find anything in the search results, PM me and I'll get you some information.
smokin 4+3
thanks guys for the info. the fluid was pinkish{tranny fluid} and was 1/2 qt low.We don't know why or how it came out of where it came out of? The fluid & filter was changed about 18 months ago with no problems after that till now.
There is a vent at the top of the OD unit. It's possible it may have gotten clogged up and some pressure might have built up and cleared any clog forcing it out the vent. Feel around at the top of the OD housing to see if there is any fluid/moisture.
BTW, it's a good idea to change the fluid and filter annually or every 12 to 15 thousand miles.
4+3 tranny smoke
thanks for the tip on the top vent,We did'nt know about that.It makes the most sense,so it will get a good look.will post after this weekends run and show.
