91 Parking Brake replaced, how to adjust?
I just replaced the Parking brake handle assembly on my 91 Vette with a new assembly and now I need to adjust it.
I've searched many old threads but, still didn't understand the procedure. I don't have an FSM for my 91 yet but, I read about disengaging the drive pawl on the handle assembly or something like that? Another thread said, I had to use a small allen wrench on the rear calipers to adjust the parking brake clearance.
Which one do I do? The parking brake would hold the Vette great before but, now the parking brake has really no holding power.
Got it!...
After looking at the old Parking Brake assembly, I found the tiny hole where a nail is to be inserted to disengage a little cam lever for the self adjusting mechanism.
I looked at the New parking brake assembly and noticed there was a tiny phillips screw in that same hole which kept the automatic adjuster disengaged.
I removed the screw and the parking brake held Great again!
When replacing the Parking Brake assembly with a new one, don't forget to remove this tiny phillips head screw located by the brake light wire connector.
