Need C4 wiring
Old Sep 18, 2011 | 09:18 PM
WilBen's Avatar
WilBen
2nd Gear
Default Need C4 wiring
Does anyone have or know where to get a diagram of the wiring for a C4?
Old Sep 18, 2011 | 09:26 PM
LD85's Avatar
LD85
You can pick up a GM Shop Manual on eBay for @ $50
Once you learn how to use it, it is the best manual you could ever want. I love mine, and just used it to rewire my under dash, firewall bilk head and to a new XFI engine management system.
Old Sep 18, 2011 | 10:38 PM
383vett's Avatar
383vett
No other way to go.
Old Sep 18, 2011 | 11:49 PM
leesvet's Avatar
leesvet
The electrical book has every drawing in the correct color code and laid out so its easy to read and understand. The flow charts that go with the drawings are detailed and easy to follow...
You can;t expect to sucessfully work on a C4 or newer without the 2 book FSM set.
Old Sep 19, 2011 | 04:37 AM
toptechx6's Avatar
toptechx6
with all previous posts, but will mention another option. A subscription to Alldata will also provide the wiring diagrams if you need them quickly and the price is less than $30 annually.
I prefer having the FSM in hand since many jobs require flipping between sections and that is easier for this old grease monkey than the electronic version, but you may feel differently.
Old Sep 19, 2011 | 04:38 AM
Cliff Harris's Avatar
Cliff Harris
My old shop manual was falling apart from 20+ years of use. I bought a new one and threw the old one away. Then I found out that the electrical diagrams are all black and white, whereas in the old one they were all in color. I guess color is too expensive nowadays.
Old Sep 19, 2011 | 09:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
From my 86 FSM
http://members.shaw.ca/dankai/Hatch%20Release.pdf
To Need C4 wiring
