new motor not starting
Old 11-02-2011, 09:31 PM
Sober1
Sober1's Avatar
Default new motor not starting
Engine seems to be getting fuel, spark, air.
When engine is being turned over it will slightly backfire into the intake.
When timing is adjusted it then sends slight backfire noise thru the exhaust.
The balance of my air diverter emission parts are not completely installed. They appear to be seperate from the controlling equip necessary for operation.
Would this cause my condition, or should the car start regardless?
Please advise in the way of trouble shooting. Where should I start?
Just installed new cap/rotor.
Thank you.
Old 11-02-2011, 10:42 PM
rodj
rodj's Avatar
Originally Posted by Sober1
Engine seems to be getting fuel, spark, air..
Checked fuel pressure at rail?
Are plugs wet?
Year model helps when asking questions
Old 11-02-2011, 11:21 PM
Sober1
Sober1's Avatar
Thanks for response.
I have checked fuel rail by simply pushing shrader valve in...fuel squirted out.
Can smell faint fuel smell after trying to start.
Can you use a tire pressure gauge to check fuel pressure?
I will check for wet plugs after trying to start.
I have checked the vacuum line coming from the f.p. regulator for fuel/fuel smell...none.
I assume diaphram is not leaking.
1989 corvete fixer upper.
rebuilt long block. 99% stock. (1.6 rockers) thats it.
Thanx again.
Old 11-03-2011, 08:10 AM
LT401Vette
LT401Vette's Avatar
If you confirm your getting fuel, check that your distributor isn't 360° out of sync.
Old 11-03-2011, 11:39 PM
Sober1
Sober1's Avatar
Rather than insist it is correct I will try turning the rotor bug 180 around.
All other things correct it should fire if that was the only problem.
I will try it now.
It will only take 10 min.
Old 11-03-2011, 11:50 PM
Sober1
Sober1's Avatar
rotor can only be installed one direction...
will try changing dist 180 after work tomorrow.
Old 11-07-2011, 08:44 PM
Sober1
Sober1's Avatar
simple mistake of dist being 180 out was the issue.
thanks for the input. another view makes the difference sometimes.
nice to hear it run.
To new motor not starting
Quick Reply: new motor not starting
