Help identifying Gas tank/Filler neck "Mystery Part"
I have an '86. To simplifiy things...There is a retainer of some sort the seems to hold the fuel filler neck assembly in place from the inside of the gas tank. Seems as if the bolts actually thread into this part rather than the tank itself. You can feel it from the inside...seems to be plastic. Any idea what this is called? Know the part number or where I might get one? (Assuming it is not just part of a liner of some sort).
One of the filler neck bolts is stripped/broken off etc., and I am hoping I could just punch out this old retainer, and replace it rather than retapping, etc.
Thank you.
Thank you.
Anyone have a pic of a tank liner out of the tank? Can't find a pic of that anywhere...
Do a search, someone sectioned their tank into 3 parts and posted pictures when they removed it to install a fuel cell.
Here it is. I posted it on your other thread too. The liner is acutally loose on the inside of the tank, not bonded. It is all one piece and cannot be separated from the tank unless the tank is sectioned and that will probably ruin the tank. Willlie
One question...The part that the bolts actually thread into from the inside of the tank is part of the liner as well then?
Is the owner of that pic a forum member? Maybe I can buy that centerpiece from him and look inside to see if the bolt retaining part is actually part of the liner,
Thanks...Man that pic is all over the internet, haha...
Hi...I thought that car looked similar. Looking more and more like it is not a separate piece from what I am being told. You'd be the guy to ask I imagine. You've probably seen it up close more than anyone else...
Thanks...
Your right, I was pretty intimate with that tank. I wish I had room to store stuff so I could help out other members, but on the other hand, what was I supposed to do with a 3 piece tank? Good luck with your project. Willie
