My upcoming build
Old Mar 14, 2012 | 09:18 AM
vetteOnTheRun's Avatar
vetteOnTheRun
Default My upcoming build
Here is what I am planning for my up comming 93' built:
1. Overhaul the motor, may have to upgrade to a 355 depending how worn everything is.
2. Add 1.6:1 rockers and upgrade springs
3. Install headers and a free flow exhaust
4. port heads to match the headers
5. Rebuild the transmission (possible shift kit install)
6. Install Richmond 3.54 gears
7. Have a chip burnt to match the small upgrades and fix the speedo with the change of the rear end gears.
Just lookin for a nice street car. All input is welcome. Newbe here.
Old Mar 14, 2012 | 09:47 AM
cv67's Avatar
cv67
St. Jude Donor '05
Skip the port match to headers instead get some bowl porting where youll actually pick up a little something. SHould be a reliable ride with a little more poop when youre done.
Old Mar 14, 2012 | 10:01 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
maybe intake port match as well.
Thats what I'm going to do with my original motor so its ready when I blow the 383 again
Old Mar 14, 2012 | 10:03 AM
Muffin's Avatar
Muffin
BINGO on cleaning up the bowls. I would add a slightly upgraded cam and lifters. The operative word here is slightly, a big lump stick will be counterproductive.
Old Mar 14, 2012 | 02:13 PM
vetteOnTheRun
thanks for the input guys. I will follow the advice.
Old Mar 14, 2012 | 02:18 PM
383vett's Avatar
383vett
An aftermarket cam will wake up your build. You're going to get a new tune anyway. You can pick up some easy hp.
Old Mar 14, 2012 | 02:22 PM
cv67's Avatar
cv67
St. Jude Donor '05
I should not have said skip port match altogether just look further than that for gains. Portmatching intake will never hurt, exhaust wouldnt make it the exaaact size as the header/gasket like to come in a tad smaller.
Not a huge deal either way though.
Old Mar 14, 2012 | 08:03 PM
littlesk8cracker's Avatar
littlesk8cracker
throw the hotcam kit on, comes with springs and roller rockers
To My upcoming build
