I have no ALDL connector Why???
I thought of that long ago but I believe it couldn't be overlooked. It's been awhile since I've seen mine but I thought they were well identified like this:
http://www.whiteracingproducts.com/images/10021766.jpg
Here's mine. It's the black plastic piece on the far right. Mine has a cover on it that pulls off toward the rear. It is attached to the carpeted panel above it. It's right above your right knee when you're sitting in the driver's seat.
I'm not the only one then. Been searching for my connector this morning and its not there. Took the panel off and had a quick look but no sign. Will now go out and get down there with a torch and see if I can locate where it has been moved to !!! 91 L98.
As for the C4, pull the panel and really dig up in there. it has to be there, or you should at least find a bunch of cut off wires. got to love PO
#33
Actually, it was common for Dealer Service Techs to unbolt these Connectors when hooking up their Tech 1's and then burying them under the Dash. You've got lot's of pictures to work with - Data Stream is spliced to the Dash so if you can find that you can probably find the Connector. As to looking for Codes, unless there's a steady Check Engine Light, there isn't any. You can scan for fuel delivery - maybe pick up on any "garbage in/garbage out" issues. Not much else.
#37
Mine was cut by a PO. I had to peice one together from junkyard parts and rewire. If you find a wire bundle (9 wires on a '93) that is coming down from the center of the dash behind the radio, that is probably it. You should find a wiring diagram so you can ID it, though mine was pretty obvious. I would think if the connector is still on there, it will be pretty obvious to find, I cannot imagine someone going out of their way to hide it on you.
#39
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
The connector should be under the dash. to the right of the steering wheel.
Where your right knee or chin will get whacked.....
