my c4 and spark plugs ?? opinions
i have a 88 c4 - med cam - just now putting afr 180 heads on -
what spark plugs does everyone recommend -
i had ngk fr5p's on but there not made now -
thanks all
thanks all
lol
another question im getting mixed messages about is when i put these new afr heads on , do i need to measure length or can i put stock sized ones back in -
afr 180 heads , fel pro gasket set - standard rocker arms
Denso Platinum TT... Have them in my 1992 Corvette Built 383... I had NGK Iridium ix and had nothing but problems... Miss at Idle, strange power curve and more... Put Denso Platinum TT's in and WoW, smooth idle, never ran like this... The best thing the were only $2.99ea at NAPA auto parts...
Suckin' gas, haulin' ass.
I would use a heat range 6 in NGK terms.
I'm running NGK BKR6E (6962) with a 0.040" gap.
The local advance auto has them in stock.
Cruise-In II Veteran
Thats a 3% gain, let me guess they sell specially cut back plugs..
Actually TPIS gives that suggstion as an old racer's trick to gain a little more "free" HP from more complete combustion due to a better flame front.
Talked to alot of people about this for my AFR setup. The consensus was not to run anything hotter than the plug listed on AFR's website. Even my local O'Reilly's said they recommend the same strength plug as AFR -- which I believe is 1 step down from OEM. (Has to do with Corvette cooling challenges IIRC.)
Also, many people caution against running a platinum plug.
AFR's are about the best chamber design...so with good quench, you don't need much to fire off the charge.
Dave
Plug style has a lot to do with things as well a Y gap in Champion which is an extended reach is always a good compromise for a street car as they run hotter at low speeds and cooler at high speeds than the equivilent standard gap plug. An example would be a R12YC vs. a R12C it is more like a R10C at high speed and a R14C at low speed. In the end it is all about how much insulator is exposed to combustion temperatures along with how much scavanging air is available during overlap so yes even cam lobe centerline choice changes plug requirements. The real key is to keep the tip temperature high enough to stay clean and cool enough to prevent pre ignition. I used Champion examples only because I am familiar with their numbering system in bigger number warmer plug along with gap style differences. Every manufacturer has various designs available so pick your own poison there. 99.999% of the plugs with exotic metals are for extended time between changes 99.999% of the C4's will never reach them with the same owner other than the few DD cars vs. the Sunday cruise cars.
Oh and if you have close to stock compression and get colder than a marine plug you have gone too cold as they run 75% WOT for extended time. Out of the harbor and throttle up until you get to the harbor you wanted to get to.
Dave
Those "Y" plugs sound like a great recommendation for street use.
I always thought heat range was related to spark intensity. Could u elaborate on heat range? (and, how would u alter range with more cam overlap?)
FWIW: Champion phone reps were the most relevant source recommending cooler plugs in a C4.
Y plugs in Champion and yes everyone makes them though with numbers I do not know. They are extended gap so more insulator hanging out to get hot. This means during light load they run hotter than a standard gap with the porcelin close to the head. A spark plugs heat range is all about the temperature it runs at. Hot enough to not carbon uo and cool enough to not glow and cause pre-ignition. The temperature is related to load how you drive the car is the most important factor. In CT after a few seconds i am over the speed limit I can not speak forthe whole state but we have law enforcement all over the place and I am for it in the end. But a few seconds here and there is about all there is it would be fun to l;ive out west and the stories I have heard where you can run WOT for miles on end. So how you use the car determines the plug temp and that determines the correct heat range. If you live in the desert and can go as fast as you want for as long as you want ( yes wildly jealous) maybe a C59YC is for you but if you live in a congested area a R12YC might be a better choice and these are wildly ends of the spectrum of heat ranges.
Cam overlap is a simple easy thing to understand. It is air blown across the chamber to clear it of exhaust gases and pull in the intake charge. It will quickly cool the plug so a hotter one needed to keep the temp up above fouling. The number 1100F sticks in my mind as ideal though not sure if that is right or not a google search might be in order there. At the end of the day it takes less than 50 HP to drive at freeway speeds as a VW bug that has 40 can go 65 and would like to think a C4 is as aero friendly as the bug so at the end of the day less than 20% of available power. You can add every power adder you like but the heat range is subject to power required by the way you drive the majority of the time.
Dave
Dave
Received 3,043 Likes
St. Jude Donor '05
Did you call AFR?
Autolite 3924 always works well.
Used the fancy expensive plugs never noticed any difference at all.
