Reading codes question
Old Apr 21, 2012 | 09:01 AM
judwall's Avatar
judwall
5th Gear
Default Reading codes question
I have an 89 C-4.When I paper clip the ALCL it flashes code 12. I know this is supposed to be the begining and ending code. The problem is it just keeps flashing 12. No other codes and it will just keep flashing 12 over and over. Does not stop. From what I understand, it should flash 3 times,pause and then 3 more times. Do I understand this right? Is there something wrong with mine? I just bought this car and am not familar with how it all works. Thanks
Old Apr 21, 2012 | 09:28 AM
c4cruiser's Avatar
c4cruiser
Code 12 is the start of the code reading sequence and another Code 12 is flashed at the end. Then the entire code sequence starts again and will run until you shut the ignition switch off.
The 12 value (like all othed codes present) is repeated three times. There is a short pause of about a second between each of the code numbers.
Are you seeing a check engine light on the DIC?
