I am stupid. Synthetic Oil and sludge in coolant
Hey guys,
So I acquired my corvette about 2 years ago and so far have put about 3K miles on it. It runs great with a few little problems, but it is my never ending projec and I like it that way.
Anyways when I first got it I did not know much about cars but I have since gotten to know a lot. One of the things I did when I first got it was change all the fluids.
Question 1. - when I got it the vette had 127K on the clock and I stupidly changed the oil and put in synthetic. I now know that you generally should not put synthetic oil in a car that has run conventional it's whole 100+K life. I have run it with synthetic for 3k and there are no leaks. It looks like after about 3k of running it has burned about half a quart but no major leaks. With that said I was wondering if it would be better to change back to conventional high mileage or keep going with synthetic?
Question 2 - since I got the car I have battled with the cooling system. I flushed and flushed but could never get the coolant clean. Finally I gave in and replaced the hoses and the radiator. Flushed some more but I just checked and the coolant is a nasty brown with mud on the radiator cap. The engine cools fine and has no over heating problems but i know it just is not right. So with that said I was wondering if you guys had any additional suggestions on how to get it right. I think the previous owner put stop leak or some gum for some reason. Now it's my problem. Any suggestions? I have been flushing with a garden hose hooked to the flush fill tap.
There is a tech tip that does a better job explaining but it is easy enough to make a hose that connects where the knock sensors go and attaches to a Y to your garden hose. Basically you take a knock sensor to home depot and match it to a pipe fitting with a barbed hose adapter on the other end then connect those to the Y via old garden hose or new vinyl hose and drain through the lower radiator hose disconnected from the radiator.
IMO a full synthetic in the proper weight is the correct oil regardless of OWT about them causing leaks.
A little bit of the stopleak isn't a problem. The factory put stopleak in C4s, for example.
5k should be close to optimal - have oil analysis done each change.
Do a search, blackstone labs has a kit where you send them a sample and they send you a report.
FYI my wife's 2004 with over 100k uses a qt every 3k - 4k. So you are in great shape.
Can you point me towards the tech article for flushing via the knock sensors? Also is there a tech for C4 vette section of the forum?
Head gaskets look like they are moist at the edges but no visible leakage. Guess I will stick with the synthetic oil!
It's possible that somebody put Dexcool (orange antifreeze) in your car. Don't EVER put that stuff in a car that has had the green antifreeze in it. It will take forever and multiple flushes to get the resulting mess out of your cooling system. Been there. Done that.
