Engine Rebuilds - L98
Anyway, I want to rebuild this engine in my garage as time and money allows and when its done, do the swap. I'm not looking to build a monster but I'd like something with more kick than stock. Here's my question, is there a complete hi-po kit I can get for the rebuild or does anyone have suggestions for components? I've seen kits for the stock rebuild, but I'd like a hotter cam, maybe roller rockers, better connecting rods and pistons, etc. I've already done fuel injectors and polished the plenum & runners on the engine already in the car, but if I have to replace them, I will. I want something streetable, dependable and able to work with the current ECM.
I'm asking a lot, I know.
Second - There are lots of kits and lots of individual parts that could be assembled into what you want to do but first I need to see your budget and how much time is going to be allotted for the build.
Will
That crate motor is a good motor and in contention. I'd have to swap out the cam and figure a way to get the compression from 8.5:1 to 9:1 to match the stock L98. Right there, I'm at $2000 so its in the budget and simple. But I want to get my hands dirty and maybe teach my 8yo something in the process.
Forged pistons like the Icon PN 9913 $330
http://www.cnc-motorsports.com/pisto...-030-bore.html
Another option is the Probe PN 2256 run about $400
http://www.cnc-motorsports.com/pisto...-5-7-rods.html
Forged rods like the Scat Pro Stock run about $200-$240
http://www.cnc-motorsports.com/conne...-sb_chevy.html
Another rod option would be the Eagle SIR $210-$250
Rings $31
http://www.cnc-motorsports.com/pisto...5-64-3-16.html
Rod brgs $21
http://www.cnc-motorsports.com/engin...-400-2-10.html
Main brgs $32
http://www.cnc-motorsports.com/engin...1968-1995.html
Cam brgs $23
http://www.cnc-motorsports.com/engin...7-350-400.html
Oil Pump $20
http://www.cnc-motorsports.com/oil-p...-pump-m55.html
That will get the bottom end built, but your gonna need a gasket set $90
http://www.cnc-motorsports.com/gaske...injection.html
That's almost $800 in parts.....
If the crank needs to be turned the brgs will change to an undersized part consummate with whatever size the crank is.
Do you just plan on re-using the factory cast iron heads??? There is no way for me to know how much work they will need without inspecting them.... but it could be just surfacing and valve job ($300) all the way to more than a new set of alum heads cost.... Edelbrock E-Streets are like $900....
The machine work on the block alone will cost about $450-$500
$50 - clean
$50 - install cam brgs/freeze plugs
$200 - bore & hone w/plate
$150 - deck ($75 per side)
Again not counting the crank... figure a min $75 to polish it and probally $150-$200 if it needs to be turned.
I can advise you on a small drive-able cam but an 86 was orginally a flat tappet and I don't recomend anyone building a new engine today build one with a flat tappet camshaft. A retro roller is gonna be about $270 for the cam (Howards) and about $325 for the retro fit lifters (Howards)....
There are also some other options for an 86 block - If it's set up for the factory hyd roller - To buy factory roller lifters ($150) but you'll also need the factory spyder and dog bones... If the 86 block is not set up for a hyd roller your SOL and stuck buying the more expensive retro roller stuff....
Last thing off the top of my head is timing chain, rocker arms and pushrods all of which depend on heads, type of cam and lifters.... Rough price est's are:
Timing chain - $100 (Cloyes double roller)
Pushrods - $130 (Manley 5/16 .080)
Rocker arms - $250 (Scorpion)
Will
A tpis 134-700 cam ( torque secrets 221/230 int/exh and 112 degr lobe sep, and the lift is abbout .45). Had higher pistons for better comp. sliight porting of heads (iron 624).ported plenum, large tube runners and big mouth intake. descreened MAF, better airfilter, tpis headers. The engine now is over 300hp and 400ftlbs.
The car is a good daily driver and have excellent throttle response and pulls over 5000 strongly and does not get breathing problems at 4700.
I am happy with the car as so far.And the gas economy is good. With driving on highway and touring I use .95/10 km.
The car is a z-51 with 3.07 differential ratio.
HAd to have a customized chip and Formato did an excellent job.
Best of luck..
Oh yea, my motor isn't back yet so the parts I bought may let me down but some other folks around here have spoke positively of Skip White Performance so I felt pretty good with what I bought.
That would be a decent upgrade and roller cam ready. You would need a few extra parts because it only comes with the block, crank,bearings, rods, pistons and rings. All assembled.
You would need the newer (87up) pan/gasket dipstick/tube and other stuff.
