Transmission leak
Old Apr 16, 2013 | 09:44 PM
rdchaplin's Avatar
rdchaplin
Default Transmission leak
I have an 86 coupe with the Doug Nash 4+3 transmission. The overdrive actually works fine. I changed the fluid and filter as soon as I bought the car. I have a leak in the overdrive where the overdrive wires pass through the case to the solenoid. I can't find any reference to a seal or O-ring for the solenoid where it goes through the case; looked through all of the Corvette parts suppliers that I can think of. Anyone else have had this issue or fix for that? Another Corvette guy told me that by switching the tail-housing the 4+3 trans can be converted to a "regular" T10. Would have thought the output shafts are different? Anyone confirm that one? The reason I am asking is because I am thinking of prepping the car to race in the Touring Car Challenge series with the Northern NJ region SCCA. I can't afford a ZF conversion or e new Richmond "spec" trans (per rules) right now and afraid the OD wouldn't hold up.
Old Apr 16, 2013 | 10:12 PM
True Mountaneer's Avatar
True Mountaneer
Yea,The output shafts would have to be different one without over drive would be a solid uninterupted shaft from the main gearbox..If you can't find any other way to get seals or grommets for them wires,I would clean the area real good and try calking around them with permatex,I doubt that they are under pressure.
