96 overheated
Old May 2, 2013 | 06:47 AM
wingnut96lt4's Avatar
wingnut96lt4
Default 96 overheated
:***** [ help Last night my vette overheated boiled all coolant from overflow tank not radiator tank. Could this be fan not going on ??? or thermostat not opening??? If anyone has an Idea would like some help. Thanks
Old May 2, 2013 | 07:01 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
if the temp was over 228 and the fan did not come on, there is a problem. It should.
What temp was it running?
Are you sure you are full of coolant?
If you are over heating, you either need a new thermostat and if that doesn't help, you probably have plugged fins in your radiator.
Old May 2, 2013 | 07:27 AM
desertmike1's Avatar
desertmike1
Could be many things!!
Start by inspecting the front side of your Radiator, shine a flashlight through the opening on the R/H side of the Fan Shroud, near the A/C lines.. Also check the front side of the A/C Condensor as well.
These cars act like Vacuum cleaners.
Old May 2, 2013 | 08:02 AM
SouthernSon's Avatar
SouthernSon
In traffic idling? cruising at speed? A/C on? Did you try the heater - was there hot air from it? Have you checked the oil on the dipstick - water in the oil?
Old May 2, 2013 | 05:47 PM
wingnut96lt4
: TAHNKS GUYS SORYY FOR YELLING I SAW MY BABY CRYING . hA hA I checked the fan goes on and off ac working fine heat is working also BUT the top and bottom hoses feel soft like very little water going thru. I think the thermostat is stuck ??? If it is what should I put in ?? 160 190 ?? All so I DO HAVE TO be carefill getting th opti wet ?? Will that do damage??
To 96 overheated
