Guess the part
Old Aug 10, 2013 | 09:24 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Guess the part
I bought a refurbished TPI setup and it came with all the bolts, sensors, hoses, etc. This was from an 89 and mine is a 91. From what I read online the only thing I had to do to make it work is to install my MAP sensor and not use a MAF.
This is one of the sensors I got with it. It does not match up with any of the ones on my car though.
Any ideas as to what it is? I am thinking it is some kind of coolant temperature sensor. The markings on one face say 35*c 8sec, another facet says 23V 40W, another says 4318, another BOSCH, another (pictured) and a circled 011 and 0280130229 and the last has Made in Germany 450. Maybe this is the coolant sensor for the 89 plenum base?
Old Aug 10, 2013 | 09:30 PM
vetteoz's Avatar
vetteoz
It won't because it looks like the thermo switch that runs the CSI used on early TPI setups ( not part of the '89 setup you bought )
The brass hex head unit to left of the CTS circled.
Old Aug 10, 2013 | 10:38 PM
corvetteronw
Cruise-In VIII
Thanks Oz! I think that is it. Anyone need one? The plastic part has a chunk missing but I bet it will still work. Freebie!
Old Aug 11, 2013 | 12:16 AM
vetteoz's Avatar
vetteoz
Freebie!
$150 new
Old Aug 11, 2013 | 01:01 AM
vette 15x's Avatar
vette 15x
Default guess part
Part of cold start system.Give it to the member with the cold start issues.
To Guess the part
